11-10-2020, 08:34 PM | #1 |
oil leaking
friend bought 30 model a at auction very low on oil,adding oil it runs out hole in bottom of flywheel cover
11-10-2020, 08:38 PM | #2 |
Re: oil leaking
Bad rear main is the most common cause.
11-11-2020, 12:31 PM | #3 |
Re: oil leaking
Hope the price was right could be major problems now.
11-11-2020, 12:43 PM | #4 |
Re: oil leaking
Either rear main issue or gasket around camshaft
11-11-2020, 06:01 PM | #5 |
Re: oil leaking
Good afternoon...You will need to drop the pan and take a look...could just be a loose rear main...might be able to remove a shim or two and tighten back up. Clearance should be about 0.015 thousands. Use Plasti-gage...or if nothing else, remove the plugs and crank it before you tighten things up and then after to feel that things are snugger than they were but the engine still turns without much pressure...some good 'A'ers do it almost like tuning a piano! Ernie in Arizona
11-12-2020, 11:37 AM | #6 | |
Re: oil leaking
11-12-2020, 01:32 PM | #7 |
Re: oil leaking
Had same problem large puddle of oil , removed two shims from rear main brg, better.
You could remove shims until you can no longer turn engine over then add one back. Do one at a time , about .006" each. Bob |
11-12-2020, 01:55 PM | #8 |
Re: oil leaking
thanks for info
