Old 10-06-2019, 02:54 PM   #1
Brian
Brian's Avatar
Default 272 starter
I normally hang out on the flathead forum, however, have a question for you boys into the late model Fords....I have picked up a 272 starter motor. It has three field windings, the third one being a bit smaller than the other two. Never seen this configuration before....question, would it be 12 volt or 6 volt?Thank you, Brian
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 10-07-2019, 04:33 AM   #2
KULTULZ
KULTULZ's Avatar
Question Re: 272 starter
Any I.D. STAMPINGS on the GEN case?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-07-2019, 01:07 PM   #3
Brian
Brian's Avatar
Default Re: 272 starter
No, nothing!
Old 10-07-2019, 02:16 PM   #4
rotorwrench
rotorwrench's Avatar
Most early ford starters have two fields and 4-brushes but holding coil types started to show up in the 50s with 12-volt. They have two fields with large wire and one fine wire field in parallel. The fine wire one is sort of a shunt coil and is generally used to limit rotational speed of the motor. Some are referred to as holding coils. From 1956 with 12-volt systems, the 3 field set up was used. They still had 4-brushes but they added 1 extra field.
Old 10-07-2019, 06:12 PM   #5
Brian
Brian's Avatar
Thank you Rotor...I'm wanting to build a 12 volt starter for a flattie, so will use this case with a flathead armature and should be good to go... thank you.
