09-21-2019, 02:48 PM | #1 |
1934 Ford rear end gear oil
Will 90 weight gear oil work in the rear end on 1934 Ford rear end?
09-21-2019, 04:03 PM | #2 |
Re: 1934 Ford rear end gear oil
Of course it will work..question do you want to do that ? I use off the self auto parts 85-140 seems to work fine..I have run 30 wt motor oil in manual trans before and it works fine ,a little noisy maybe..model A era they used heavy oil..150 wt +-..sc
09-21-2019, 04:07 PM | #3 |
Here's what I use in the rear of my '35 and '36 only because it's compatible with the yellow metal in the trans and I don't have to stock two fluids... https://smile.amazon.com/Sta-Lube-SL...qid=1569099984
Ooops sorry about that first pic. Second one is good stuff, first one is pure trouble.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 09-21-2019 at 04:24 PM. |
09-21-2019, 09:25 PM | #4 |
