06-11-2019, 01:44 PM | #1 |
Best way to lower the front '41 coupe?
I'd like to lower the front of my car 1in., I just put "15 radials on three years ago, so the whole car is down a couple of inches but I like to go 1 more inch in front. Ideas?
06-11-2019, 02:22 PM | #2 |
Re: Best way to lower the front '41 coupe?
Reversing the stock spring eye's will lower your car 1 more inch. Keep an eye on your scrub line.
There reaches a point where,if you lower it too much, you won't be able to get a jack under the car axle to raise it in case of a flat tire. Then you need 2 jacks, 1 to raise the frame and body and another to raise the front axle. Here's more: https://www.fordbarn.com/forum/showt...ower+front+end You could take a leaf out of the spring. That's probably the easiest way to go. |
06-11-2019, 03:22 PM | #3 |
Reverse the spring eyes. A spring shop should be able to take care of it.
06-11-2019, 09:28 PM | #4 |
I purchased a reversed eye Posies spring which was supposed to fit the '41, but it was almost an inch too short, and would have made the shackles too flat, which causes dangerous side loads on the perches. I adapted some 4" shackles to 3" and that got the shackle angle near 45 degrees. With that spring swap, the drop was maybe 3/4 inch.
The Posies spring is softer and low friction between leaves. I had to really stiffen the front shocks to get the ride dampened. My recommendation, take out the second and fourth leaves of your stock spring. That is about 1/2 inch of spring thickness, and maybe another 1/4 inch of softer spring. |
06-11-2019, 10:07 PM | #5 |
On my '41 I removed every other leaf and sub'd a chassis Engineering reversed eye '40 main leaf with stock shocks. About the best ride I could get with stock set-up.
06-12-2019, 05:59 AM | #6 |
06-12-2019, 10:37 PM | #7 |
I replaced the Posey spring bolt with a correct square headed bolt. I left it loose enough that the upper leaves weren't pressing on the main leaf. It made installing the spring a hands only job. No spreader necessary. After the shackles were installed I tightened up the center bolt and cut off the excess. Easy Peasy.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
06-13-2019, 06:23 AM | #8 |
Turn the front wheels until a tyre protrudes out of the fender. This will give you a rough idea how much you can lower the front before you start to scrub against the fender when you turn.
Allow a little extra room in case you hit bumps when you are turning. I have 6.50X16's on my 41, and there ain't a lot of room for lowering the front. |
06-13-2019, 06:31 AM | #9 |
longer shackles, cheep.
06-13-2019, 05:28 PM | #10 |
I had the local truck shop make me a new reverse eye main leaf. Cheapest way out. I think I also removed 2 upper third leaves. Lowered about 2 in. and still rides the same. Total cost $60. I don't like longer shackles.
06-13-2019, 06:39 PM | #11 |
This would be the most correct way to do it. Pulling the top two short leaves plus the new reversed leaf should get you down at least 1 1/2 inches. Have a spring shop make you the reversed leaf.
06-13-2019, 09:17 PM | #12 |
Or reverse the main leaf your self. It's pretty simple if you take your time.
06-13-2019, 10:29 PM | #13 | |
Actually, I had never heard that one before. It really made me giggle. |
06-14-2019, 11:09 AM | #14 | |
There are warnings about too-flat shackles on older threads. |
06-14-2019, 11:41 AM | #15 |
06-14-2019, 12:52 PM | #16 |
The title of this thread is, what is the BEST way to lower a 41 ?
The BEST way is a dropped axle. |
06-14-2019, 01:38 PM | #17 |
I used a Magnum 4” drop axle which actually lowers the car 2”. It works and performs perfectly and the car handles well (I dropped the rear slightly more than the front, I hate a forward rake on fat fender cars.)
The drawback is you have to either bend or cut off and replace the spindle steering arms. I did the latter and as I said it works perfectly. |
06-14-2019, 01:39 PM | #18 |
P. S. You can see the stance of the car in my avatar.
06-14-2019, 02:31 PM | #19 |
I'm for big and littles.....................
Paul in CT |
06-14-2019, 02:36 PM | #20 |
I like dropped axles, but no where near as simple as reversing the eyes on the spring! I'd do both, but I like them low.
