03-05-2018, 05:23 PM | #21 |
Re: How Long Does It Take For your Car to Overheat
With a GOOD cooling system.........................NEVER
AL in NY |
03-05-2018, 05:52 PM | #22 |
In about 25 Miles after a re-build at a Restoration Shop in Tenn..
03-06-2018, 10:59 AM | #23 |
Thermocure by Evapo-Rust Cooling System Rust Remover and Flush - $20
Prestone Radiator Flush & Cleaner - 22 fl oz bottle - $4 Both at Walmart, Evapo-Rust work very, very good, top of the line stuff, the Prestone works very good also for the price. Run it in the car for several days depending on how many miles you drive. And my car does not overheat, in fact she runs almost to cool.
03-06-2018, 11:14 AM | #24 |
I basically agree with Steve on his comment.
At idle with the spark fully retarded, it should not overheat. If you were to drive the car with the spark fully retarded, you should expect it to overheat. Check your timing, carb settings and your radiator. I agree with you...your radiator is not up to needed capacity. Good Day! |
04-25-2018, 08:09 AM | #25 |
I have never had a problem.
04-25-2018, 08:33 AM | #26 |
04-25-2018, 03:30 PM | #27 | |
04-25-2018, 03:57 PM | #28 |
A few years ago I bought an IR temperature measurement gauge from Harbour Freight. Just aim the laser at an item and it tells you the temp. Comes in handy to measure temp of water doing into the radiator and what is coming out.
I also watch tire temps on my hauler trailer. An abnormally high temp gives me a hint that i need more pressure.
Live in the Past.... It's cheaper. |
04-25-2018, 05:04 PM | #29 |
It's been about 20 years, and mine hasn't overheated yet.
