06-30-2013, 02:32 AM | #1 |
1934 Ford 3 window vs. 1934 Ford 5 window
My restoration project of my avatar 1934 Ford 3 window, while becoming very expensive, is coming along fairly well.
I do have a question - Did both the 1934 Ford 3 window and 5 window coupes have the rear window that cranked down? I have been told that possibly one of the two did not have that feature. Now back to the shop for another few weeks. |
06-30-2013, 05:43 AM | #2 |
Re: 1934 Ford 3 window vs. 1934 Ford 5 window
ALL of the 34 3-W and 5-W have the roll down rear window. The window is for ventilation not for the purpose of talking to any one in the rumble seat. BOTH cars with a trunk and a rumble seat have the roll down window. If your car has the drip tray under the window area, this is only part of the assembly. There is a wood frame around the window area and the glass channels fit inside the wood, the window regulator fits inside the wood just under the window opening.
06-30-2013, 08:12 AM | #3 |
Roll down rear window in 34 is how I talk to people riding in the rumble seat.
06-30-2013, 09:56 PM | #4 |
My 34 5 window did not have a roll down rear window.
07-01-2013, 12:51 AM | #5 |
Interesting - Where would one go to find out why or why not one coupe would have a roll down over the other style? If both have rumble seats, as does mine, then shouldn't they both have a means to talk to the rear passengers? JMHO
07-01-2013, 01:09 AM | #6 |
07-02-2013, 08:48 PM | #7 |
My 34 3w has the wind down rear window,
Lawrie |
07-02-2013, 09:11 PM | #8 |
07-02-2013, 09:42 PM | #9 |
07-03-2013, 01:17 AM | #10 |
David J, my 1934 3 window is fully apart. I will try to remember to get a picture for you of the rear window or what is left of it at this point.
The window does have its own channels like the doors do. There is a large "box" under the window that catches the water and it has a drain pipe out the right lower side. That pipe bends downward about 3 to 4 inches where then a rubber hose (?) continues the drain. Of course, my "rubber hose" or whatever was supposed to be there, long ago rotted away. Then as you might have figured out, the water drained under the rumble floor mats and walllla! Rust under that mat in the floor boards. So now I have a complete new floor from back to front including the firewall which was apparently damaged in a frontal crash many, many years ago and never correctly repaired. This is getting to be a long drawn out project but I am sure learning about Henry and his ideas, silly or not. I hope to have this girl sealed up so tight that no drop of water can get into it ever again or at least not on my watch. |
07-03-2013, 01:19 AM | #11 |
Oh yes, I am still interested in knowing if the 5 window coupes had roll down rear windows?
If not did they ever come with rumble seats? Then... IF they (the 5 window cps) had rumble seats, and no roll down rear windows, just how did you talk to the rumble passengers???? |
07-03-2013, 03:25 AM | #12 |
My 34 5-w coupe has always had a trunk, and it has always had a roll down rear window.
07-03-2013, 08:24 AM | #13 |
My 34 has roll down window with rumble seat and has a box with drain pipe and rubber extension which drains water out the passenger side inside the rear wheel well.
07-03-2013, 08:37 AM | #14 |
Interesting note, I have original bill of sale from Ford and 34 sold for 393.90 + 40.50 adder for rumble seat. with all taxes total was 516.08. Dated 8/20/34.
07-03-2013, 09:31 AM | #15 | |
Thanks but pics aren't needed as I am quite familiar with the back window setup on 33-34 coupes . My first post was looking to see how his had been modified to NOT have a roll down window . I've seen these with fixed rear windows before but it was nothing done by Ford . The first post by Terry OH gave the right answer as all 33-34 coupes had roll down rear windows as far as my experience goes .
07-05-2013, 07:19 PM | #16 |
My '33 5-window had a trunk and did have the roll down window, which I have retained.
07-05-2013, 08:11 PM | #17 |
my 34 5 window had been restored before i got it this year and still had the original drain hose it was hard as a rock
07-05-2013, 08:22 PM | #18 |
1933 & 1934 Ford coupes were listed as available without or with a rumble seat. The rumble seat was an EXTRA COST OPTION costing around $40.00. I have a 1934 deluxe Australian built 5 window with both rumble seat and wind down rear window. I have studied these coupes for 45 years plus and observed rumble & trunk fitted cars with and without the wind down rear windows. However most without the wind down rear window were 1933 cars and more likely to be standard models. I have much literature on these cars and wind down rear windows are barely mentioned. About all is stated is its purpose was for ventilation or air flow and not mentioned was conversation with rumble seat passengers. Maybee now and then some assembly plants ran out of rear window winder assemblies and so did not fit them, who knows ??. That's my two cents worth anyway. Regards, Kevin.
04-04-2015, 01:03 AM | #19 |
I know this is an old post, But it sparked my interest and reminded me of a recent conversation about How many So called Early Ford experts there are out there Who Never worked in a Ford plant And Most likely wasn't even Born when these Cars were being made. Anyhow I can tell you for sure that Not all 1933 ford Coupes had roll down rear windows, As I had a 33 five window body with a fixed back window, At first I thought maybe Someone later made it that way, But the Garnish molding was about 3/8 wider than all the other coupe rear window garnish moldings I ever seen, Not sure if it was a Canada or overseas Car, But it was factory that way.
04-04-2015, 02:16 AM | #20 | |
I for one am very interested in this . Heard this before but never saw the example talked about . If true I would really like to ask some questions about how it was done . Definitely seen 33 coupes with fixed rear windows before but nothing Ford did . ADDING Have you ever looked at a 33 sedan delivery rear window garnish molding ?
