10-11-2019, 12:45 PM | #1 |
Gas Sending Unit
I just put in a new sending/fuel pump unit drove 100 miles and the gage still says full.( History) 1940 Ford Sedan,1990 5.0 HO,all Mustang underneath. Someone put in a 1987 Aerostar sending unit. I have put in new Autometer gauges and a Classic Instruments fuel link. My problem is the sending unit is still reading 158 ohms which is telling the gauge that the tank is still full. I checked the float operation and ohms before installing. HELP
10-11-2019, 08:32 PM | #2 |
Re: Gas Sending Unit
You might already know it, but the gauge and sending unit have to match. The gauge advertisement will tell the ohms required from the sending unit. If you have done that, excuse the post.
10-12-2019, 10:47 PM | #3 |
Some of the modern sending units have an adjustable float arm. You need to know the depth of the fuel tank first. For deep tanks, the float arm can be adjusted so that the float is farther away from the fulcrum. For shallow tanks, the float arm needs to be pushed inward closer to the fulcrum.
Now, if the gas tank sits at a slant normally, there is a whole nother problem, because you will run out of gas when the level goes down to where the end of the pickup tube is (often in the middle of the tank), yet you may have 3 or 4 gallons in the tank. This needs to be taken into consideration when adjusting the float arm. |
10-13-2019, 12:12 PM | #4 |
Have you tried calibrating the fuel link. I believe it has half a dozen presets. Try calling classic instruments.
10-13-2019, 03:04 PM | #5 |
The fuel link is fine have been in touch with classic the sender is putting out 158 ohms which is telling the gauge that the tank is full
10-14-2019, 11:08 AM | #6 |
Just a thought. |
10-15-2019, 08:49 AM | #7 |
yes i did
10-16-2019, 08:10 AM | #8 |
Some tech tips here: https://www.tanksinc.com/index.cfm/p...cat/cat159.htm
10-16-2019, 04:21 PM | #9 |
That is a head scratcher, you should have used between 4 and 5 gallons. What tank is in the car the 40? Any chance that the depth would be greater than a Aerostar and effect the float staying up longer?
