07-18-2017, 08:30 PM | #41 |
Re: Floorboard bolts/cup washers
Dennis, a second thank you for posting the dimensions of the screws and washers. Not many of us have original hardware from the floorboards, they were lost years ago. It appears the screw length is between 1 1/8" and 1 1/4", so maybe modern 1 1/4" screws aren't too far off - now for the heads.
Rusty Nelson |
07-18-2017, 09:20 PM | #42 | |
07-20-2017, 10:19 AM | #43 |
I'd like to thank Dan for "reviving" this 5 year old post,..I think it was from one of are
emails..? I went hunting last night for the Auveco floorboard washers....I forgot how small these guy's are! With Dennis's dimensions I checked the ones I have from Auveco,..the sizes are VERY close! The only dimension that Dennis left out was the head diameter of the screw,.. which is .425" . Making / reworking the washers is not that hard,..making the screws with the correct head diameter is another story...and I'm SHORT 4-5 to make a set. Since Auveco has been around since 1916 they very well could have been the "original suppler" to Ford. If you need better / clearer photos than the one I posted in #14...speak up.. |
07-20-2017, 10:39 AM | #44 |
Unfortunately the crooks at photobucket are holding my pictures in #2 hostage. When I get time I will have to fire up my old computer and find those pictures again. Maybe I can find my original floorboard washers and take another picture.
07-20-2017, 11:14 AM | #45 | |
JS book, but didn't find it. This COULD help Charles's , but I wouldn't do it, if it's NOT in the JS you will confuse the judges and they will down-grade you on it! Just fix the repops are find the Auveco ones.. I think I may/could have one,..BUT the O.D. is a little larger and could be for the doors or firewall.. |
07-20-2017, 11:40 AM | #46 |
07-20-2017, 01:46 PM | #47 |
Just to add more confusion I was looking in the body parts list and it shows
A-35244 Washer (floor board No. 1 Accelerator) and A-35148-R Washer (floor board No. 2 gear shift). So did they use different washers or are these numbers something totally different? The one the parts book shows for the choke seems to be 351276-S2 No. 12 finishing washer. Bob |
07-20-2017, 03:03 PM | #48 |
Dennis,
Is the shinier washer in post #46 the choke washer you got from Brattons? If it is and the darker washer is an original floorboard washer, the two look nearly identical to me - are they the same - measurement-wise? Thanks for posting the pictures. Rusty Nelson |
07-20-2017, 05:04 PM | #49 |
Rusty, the shiney one is for my choke, from either Snyder's or Bratton's. If it wasn't plated, it would be hard to tell them apart if it were installed on a floor board. Measurements are very close between the 2.
07-20-2017, 05:11 PM | #50 | |
07-20-2017, 05:30 PM | #51 |
Post #23 that i put up is a clear cut picture on an original floor board screw on an original floor board
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
07-20-2017, 06:29 PM | #52 |
This is what I have, the Auveco's..
The second photo isn't all that great,..but the first works. |
07-22-2017, 05:37 PM | #53 |
Try Roy Nacewicz Enterprises in Carlton, Michigan. I purchased these items for my 1932 and they looked pretty good in S-2 black finish. Ed
03-25-2020, 08:25 AM | #54 | |
ds |
03-25-2020, 09:10 AM | #55 |
Bought some from Mc-Master-Carr
Bob |
Thread Tools | |
Display Modes | |
