Old 04-21-2017, 12:47 PM   #21
Lawson Cox
Lawson Cox's Avatar
Default Re: 36 gas tank neck help !
Originally Posted by Brian View Post
I have never succeeded in getting the one in my 35 to seal; I've tried two tanks, I'm currently using a thick leather washer with a loctite product instead of the lead ring, I've got the proper 'C' wrench which I tighten with a length of pipe to increase leverage/torque, and if I fill my tank to the brim, it'll leak every time. Beats me!!
I had to use 2 lead washers on my 35 PU.
Old 04-26-2017, 03:29 PM   #22
FordCabriolet1936
1936 Ford fuel tank filler pipe spanner wrench McMaster-Carr #5475A16
FordCabriolet1936 is offline   Reply With Quote
Old 04-27-2017, 06:56 AM   #23
barnfind
Good info -thanks
Product Detail
#5475A16
Fixed Pin Spanner Wrenches for Holes for 2-1/4" Circle Diameter, 17/64" Pin Diameter, 1/4" Pin Length
https://www.mcmaster.com/#catalog/123/2755/=17dmoz1
$13.57
barnfind is offline   Reply With Quote
Old 05-04-2017, 07:54 PM   #24
Bondolero
Bondolero's Avatar
Got the spanner and neck won't unscrew, maybe have to remove the wheel and use a persuader pipe ?
Bondolero is offline   Reply With Quote
Old 05-16-2017, 09:38 PM   #25
Bondolero
Bondolero's Avatar
Got the neck out, pipe sealant on threads of pipe threaded neck and it was not leaking. The leak was occurring at the second arrow where the flanged neck slides inside the pipe neck.
Had a lead seal (as pictured) and still leaked like a sieve.
Ordered a new lead seal but a lot of work if it doesn't work, remove fender, drain tank down.
Also pictured the the Drake flexible gas neck than will fit either of the diameter (very stretchable.
Tempted to go ahead and cut flanged neck off and connect to pipe neck with Drake hose.
Using gas proof Permatex pipe thread sealant worked very well on threads tho.
Welcome any ideas before getting out the cutoff tool.
Old 05-18-2017, 03:23 PM   #26
rich b
rich b's Avatar
If the lead seal seemed OK and the threaded outer tube was tight, there is a another possibility. I have seen where road dirt has built up between the inner tube and the outer tube which resulted in rusted pin holes in the inner tube.
Old 05-18-2017, 03:57 PM   #27
barnfind08
I have the ford nos leaded washers
barnfind08 is offline   Reply With Quote
Old 05-19-2017, 07:50 AM   #28
Mike..Yorba Linda
I use two lead washers. Also, the Drake filler tube is not bent enough and will be slightly shorter the OE Ford filler tube.......
Mike..Yorba Linda is offline   Reply With Quote
Old 05-19-2017, 11:47 PM   #29
Bondolero
Bondolero's Avatar
Filler neck is not drake, and the original is not rusty.
I am wondering if I should put the fender on and position the filler tube prior to tightening the threaded neck against the lead seal, otherwise it would seem you are taking a chance if you rotate the neck after you have seated it against the lead seal ??
Old 05-20-2017, 12:53 AM   #30
Brian
Brian's Avatar
Obviously this is the way to do it. Pays to leave the rear fender brace off too, to give you more 'swinging room' for the wrench. Also pays to have a helper to hold the filler neck in correct orientation from above, whilst you swing on the wrench from below....
Old 05-20-2017, 01:31 AM   #31
Bondolero
Bondolero's Avatar
Looking at these seals, I am surprised gasket material will not work, heck your carb and fuel pump have gaskets on them ?
Old 05-20-2017, 01:37 AM   #32
Brian
Brian's Avatar
I too am surprised...see my earlier post where I explain I'm currently trialling a thick leather seal [to no avail]. I cannot get lead to seal, nor peek [a special synthetic plastic stuff]. Beats me, it is damn hard to seal petrol for sure.
Old 05-20-2017, 11:33 AM   #33
Bondolero
Bondolero's Avatar
I think a friend can get his tig welding to seal after I cut the heck of one of Henry's bright ideas. The lead is not a good crush material to seal something as primitive as the flanged steel neck edge of the gas neck. If it was a flat surface to flat surface - maybe.
At least now I have a spanner to take it back off and fix it . Thats a positive.
Old 05-20-2017, 03:04 PM   #34
36Bill
36Bill's Avatar
Would a large O ring work? I was able to seal mine with lead but it's not easy.
The best way to have a friend is to be a friend. Howdy Doody
36Bill is offline   Reply With Quote
Old 05-20-2017, 06:26 PM   #35
Bondolero
Bondolero's Avatar
Trouble with using o ring or gasket it has to be fairly thick and fuel resistant to seal the flange. If you just use a regular o ring it is not thick enough to absorb the crush needed to seal. Thats why guys are having to use two to ever get results.
I don't mind that but don't want to wait another week for a stupid lead ring to come. If I could get someone who will pri mail it please contact me . [email protected]
