02-17-2013, 04:38 PM | #1 |
Motor Mounts
I'm replacing my motor mounts..any benefits of using Float a motor or should I stay with the originals ?
02-17-2013, 04:53 PM | #2 |
Re: Motor Mounts
Wow, this must be whip the dead horse day. People either love 'em or hate 'em, and they present theory, testimony, and conjecture both ways. Put "Float a motor" in the search (black bar above) and watch the re-runs of many bouts.
02-17-2013, 05:37 PM | #3 |
Re: Motor Mounts
they work, they will remove almost all viberation that is transfered from the engine to the frame and body, makes for a very smooth ride, some say that using them weakens the frame integerty, but on the other hand using the stock ones puts a lot of stress on the block, they are bolted directly from the engine to frame with a lot of viberation, ive used them and found them to be very pleasant , but if you tighten the float a motor rubber bisquits to tight they will feel like solid motor mounts, if you have a set try them and then decied for your self, but be prepared for the original nuts to jump all over you for just even thinking about using them
02-17-2013, 11:16 PM | #4 |
Re: Motor Mounts
Question answered ...Thanks...I was shoveling snow all day....should have just searched it
02-18-2013, 11:08 AM | #5 |
Re: Motor Mounts
