Old 07-13-2018, 06:41 PM   #1
midgetracer
midgetracer's Avatar
Default Rh and Lh steering column tubes
Is there a difference between the RH and LH steering column outer tube (the one with the throttle and accelerator levers)? I have reviewed the book by Les Pearson and cannot find the answer. I know the gas lever has no ball on the end, but cannot see another difference.
midgetracer is offline   Reply With Quote
Old 07-13-2018, 07:25 PM   #2
quickchange
quickchange's Avatar
Default Re: Rh and Lh steering column tubes
No difference in the tube , spark & throttle rods are different ,in that the holes through the levers are at a different angle , too LHD , hope that helps,
quickchange is offline   Reply With Quote
Old 07-13-2018, 08:18 PM   #3
midgetracer
Thanks Derek, I knew you would have the answer.
Old 07-13-2018, 08:23 PM   #4
Synchro909
Synchro909's Avatar
Too late!
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
