Old 08-16-2019, 09:30 AM   #1
marty in Ohio
marty in Ohio's Avatar
Default Fan Belt Squeak
My fan belt is not too old but it is starting to squeak a bit. What can I use to dress it? I have some belt dressing in a spray can in the garage but it makes such a mess when I use it. I remember years ago there was something like a crayon that would help. What do you say?
Marty
marty in Ohio is offline   Reply With Quote
Old 08-16-2019, 09:41 AM   #2
Dick So. Cal.
Default Re: Fan Belt Squeak
Try bar soap. Works every time.
Dick
Dick So. Cal. is offline   Reply With Quote
Old 08-16-2019, 10:54 AM   #3
ryanheacox
ryanheacox's Avatar
I recently had the same problem and tried all the common dressings, none worked.
I ended up sanding the belt, nice and quiet now.
Old 08-16-2019, 01:01 PM   #4
WHN
Try WD40. Just spray a little on belt at top of generator. Very little.
Has always worked for me. No mess. Enjoy.
Old 08-16-2019, 01:49 PM   #5
F.M.
With engine running SLOW, A bar of bath soap held on belt edges..
F.M. is offline   Reply With Quote
Old 08-16-2019, 01:53 PM   #6
The Master Cylinder
The Master Cylinder's Avatar
Not recommended. The fan is turning right there. Have someone turn the engine over with the hand crank.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-16-2019, 01:59 PM   #7
Werner
Werner's Avatar
Hallo Marty, the squeaking comes when the V-belt slips. If you apply a lubricant such as soap or WD40, you will not hear it squeak anymore, but the belt is still slipping. The solution is candle wax. Rub the flanks of the V-belt with it and the belt runs noiselessly and without slipping.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-16-2019, 02:09 PM   #8
WHN
Disagree!
Squeaking is not just caused by slipping fan belt.
The Model A’s generator isn’t always in perfect alignment with the other two revolving pulley’s. As the belts age, the edges dry out, and the slight mis-alignment causes a squeak.
I am never 100 percent right, but I’ve been at this for a long time. Try the WD40, just a very little on generator pulley. Enjoy.
Old 08-16-2019, 02:28 PM   #9
The Master Cylinder
If your worried about slippage, use Gasgacinch Gasket Sealer and Belt Dressing https://www.amazon.com/Gasgacinch-44...s%2C199&sr=8-1
The Master Cylinder
Old 08-16-2019, 02:49 PM   #10
marty in Ohio
Thanks for all the replies. I did spray with WD40 a week ago but I think that is a temporary fix. The squeak came back. Now I have a bunch of things to try.
I can't wait to get started.
Marty
Old 08-16-2019, 02:55 PM   #11
ryanheacox
ryanheacox's Avatar
Marty
My experience as well. If you look at the sides of the belt you'll probably see that the belt is glazed. Sanding cuts this glaze and quiets the belt, no dressing required.
Old 08-16-2019, 03:09 PM   #12
sphanna
sphanna's Avatar
ryanheacox. times 2 :-)
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 08-16-2019, 03:44 PM   #13
Mulletwagon
Mulletwagon's Avatar
Might try a new BX40 or BX41 belt. It is the cogged type and may help.
Mulletwagon is offline   Reply With Quote
Old 08-16-2019, 04:26 PM   #14
mhsprecher
mhsprecher's Avatar
We used to use Door Ease, it comes in a stick and you rub it on the belt edges. https://www.amazon.com/AGS-DEK3-Door.../dp/B000CIFVN6
mhsprecher is offline   Reply With Quote
Old 08-16-2019, 05:27 PM   #15
Y-Blockhead
Y-Blockhead's Avatar
Yes!! I had forgotten all about Door Ease! They always had Door Ease around the service station I worked at when I was a teenager. We kept it out in the cash boxes on the islands so we could put it on customers "squeaky" belts. Part of the service... check oil, water, air, wash windows, meet girls, etc. Great times, not much money.
Of course this was back when they had service stations, cash boxes and service attendants.
Thanks for the memories.
Old 08-16-2019, 06:31 PM   #16
mike657894
mike657894's Avatar
you can cure a squeaking belt by cleaning it and the pulleys. soap and water.
mike657894 is offline   Reply With Quote
Old 08-16-2019, 07:37 PM   #17
CarlG
CarlG's Avatar
I have used all of the above, except the sanding. Nothing seemed to work except putting a new belt on. I'll have to try the sanding next time. Oh, I did (do) have the cogged belt.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-17-2019, 04:07 AM   #18
john charlton
john charlton's Avatar
ATF you do not need to dress all the belt it will migrate around by itself when running . This works for me and seems to be a long lasting cure .
John in sunny morning Suffolk County England .
