05-28-2019, 11:33 AM | #1 |
How to remove blasted carrier bearings without ruining them
I have been working on the rear diff and I knew I had to add shims under the carrier bearings due to them having spun. The machine shop had them knurled and estimated how much they took off. So I assembled the carrier with the shims and installed the bearings. Low and behold, with .046 in gaskets I still had the carrier locked up so I knew I had to remove some of the shims. I tried in vain to pull the bearing with no luck and bought a bearing splitter at HF but essentially ruined the bearing. So Im out ~50 bucks just for one side to buy another bearing and try again.
Is there some trick to getting the bearing splitter under there? I tried a 3 jaw puller but there just isnt enough to grab onto. The bearing splitter worked but it pulled on the cage and now the cage is extremely loose. So much so I woudlnt use it Frustrated in Ohio!! |
05-28-2019, 11:48 AM | #2 |
Re: How to remove blasted carrier bearings without ruining them
I use what is called a knife-edge puller, and hold it tight against the back side of the bearing with a C clamp, then put in a press and push on the carrier using a socket of the proper diameter. Good luck. The cage being loose may not be a problem, it just keeps the rollers in place but no load is actually on it.
05-28-2019, 12:12 PM | #3 |
I had the same problem early on. I had a friend make a small bearing puller for me that had sharp edges I could slide under a bearing hub so as to pull it of without damage if I had to remove a new one in order to add more shims.
To make it easier whenever I have carrier assemblies knurled I have the machinist take an extra cut under the bearing stop to facilitate the use of a standard bearing puller. The attached is an article about pulling a new bearing off. Tom Endy |
05-28-2019, 01:38 PM | #4 |
HI Tom
Yes, I read the article but for the life of me I could not get the bearing puller under the bearing as you showed. The one from HF is thicker and it simple would not fit with the knife edge up. I had to install it with the knife edge down and it only connected with the cage. I tried to see if there are dimensions out there for other bearing splitters but I couldn't find anything that talks about the height (only min width, max width, bearing dimension etc.) but not actual height of the splitter . |
05-28-2019, 02:45 PM | #5 | |
Be careful using 3 jaw pullers as they will not work and distort the bearing unless of course you don’t care about them. All the best! Larry shepard |
05-28-2019, 05:08 PM | #6 |
05-28-2019, 07:42 PM | #7 |
Mount the carrier in a vice and take a putty knife and hammer and see if you can tap it into where the bearing seats. If you can move it off the seat a little you might be able to get a screw driver in there to pry it up further. Once off the seat a little you should be able to get the bearing puller under the hub. Depends on how tight the bearing is on the hub.
Tom Endy |
