Old 03-09-2013, 08:41 PM   #1
Wilbur
Wilbur's Avatar
Default 6 Volt LED Flasher
Has anyone been able to find an electronic flasher to run these great 6 volt LED tail lights that the vendors are selling? I bought the lights, figuring that in combination with my incandescent front signals, l wouldn't need a special flasher. Well, they work but the flash rate is too short. I realize that the circuit lacks the resistance to let the thermal flasher work as it should and that by adding another bulb in the line, it would flash the right way. It seems that they don't make these in 6 volt...
Wilbur is offline   Reply With Quote
Old 03-09-2013, 09:10 PM   #2
ctlikon0712
ctlikon0712's Avatar
Default Re: 6 Volt LED Flasher
Here is a make your own......
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 03-09-2013, 09:35 PM   #3
Paul in Colorado
Paul in Colorado's Avatar
Mine work with a regular flasher, using 10 cp bulbs from Brattons in the cowl lights.
Paul
Paul in Colorado is offline   Reply With Quote
Old 03-09-2013, 09:35 PM   #4
Allanw
Allanw's Avatar
I'm also an aircooled VW nut, so used one made by Wolfsburg West:
http://www.wolfsburgwest.com/cart/De...D=111953185BWW
I don't have LED lamps, but have heard of others using it OK with LEDs in their VW's. I guess you should check first!
The first thermal flasher we got was erratic and would alter rates, depending on what lights were on, and would just stop flashing sometimes. The Wolfsburg West one flashes the same rate all the time, and also flashes the lights as soon as the switch is on - there is not delay like out old thermal one had.
Allan
'29 Tudor, Canadian RHD
Whangarei, NZ
"Duct Tape can't fix stupid, but it can MUFFLE the sound"
Allanw is offline   Reply With Quote
Old 03-09-2013, 09:50 PM   #5
Wilbur
Wilbur's Avatar
The WW unit looks like a good bet. Allan, did you have any issue with the the A being positive ground. Making a flasher is pretty cool, but my "to do" list is huge, and it's almost boating time here in Jersey... Rather buy it for 20 bucks and call it done.
Old 03-09-2013, 11:09 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Here is a flasher I bought from Fleet Farm about 8 years ago. It was the last one they had and they never reordered. It's made for 12 volts, but also works on 6 volts and will flash with only LED's and up to a 25 amp load. Sure wish I could find more of them.
Old 03-10-2013, 12:01 AM   #7
Willie Krash
Willie Krash's Avatar
Tom,
They are on eBay if you are looking for them. $11.50 with shipping.
http://www.ebay.com/itm/2-VICTOR-EF3...-/320370519349
Willie Krash is offline   Reply With Quote
Old 03-10-2013, 02:30 AM   #8
Tom Wesenberg
Thanks Willie. I just picked up two more. For the first one I think I paid $3.98 at Fleet Farm.
Old 03-10-2013, 08:16 AM   #9
supergnat
supergnat's Avatar
I just found this source. http://www.memotronics.com/product?pid=1273#
Never usethem though.
supergnat is offline   Reply With Quote
Old 03-10-2013, 08:48 AM   #10
Wilbur
Wilbur's Avatar
Thanks Willie. I just ordered the same. Tom, do you have one of these on a 6 volt car now?
Old 03-10-2013, 11:17 AM   #11
Tom Wesenberg
No, it just sets on the shelf for now.
Old 03-10-2013, 01:41 PM   #12
Russ Koch
I see all the flashers you guys are talking about are 2 prong. I have a 3 prong with a series 900 signal-stat switch. the third prong is for the pilot light in the switch. Do you guys find the 2 prong flashers better,easier to find,last longer? The flashers I have been finding don't last worth hoot!
Russ Koch is offline   Reply With Quote
Old 03-10-2013, 03:33 PM   #13
eagle
eagle's Avatar
One thing to remember, most of the electronic flashers are for negative ground, just switch the polarity on the flasher and they will work just fine.
eagle is offline   Reply With Quote
Old 03-10-2013, 04:15 PM   #14
Allanw
Allanw's Avatar
Buying is easier!
I didn't have an issue with positve ground... ours is 6 Volt negative ground
They just get wired in the other way though. I Fitted a peizo siren instead of the dash indicator to remind us they are on - the light in our old switch is 12V, so I haven't wired it up, and I'm so busy driving the thing, I'd never see the light anyway - buzzer is good!
Allan
Whangarei, NZ
Old 03-10-2013, 09:08 PM   #15
AL in NY
AL in NY's Avatar
I tried to build Tom Wesenberg's flasher as drawn and couldn't get it to flash at a nice slow cycle. I believe you need to replace the 130 ohm resistor with a variable potentiometer (ie 0 to 250 ohms) and vary the resistance until you get the rate you like.
AL in NY
AL in NY is offline   Reply With Quote
Old 03-10-2013, 09:18 PM   #16
Tom Wesenberg
A larger capacitor (more mfd.) would slow the flash rate.
Old 03-11-2013, 03:54 PM   #17
Christoph
Christoph's Avatar
There should be lots of info using "search"-option
I had to go forward once my "old-style-mechanical-flash-relay"
started burning while driving the car.... no fun.
I use "m-flash" (with buzzer) and its great:
http://motogadget.com/en/m-flash-blinkrelais.html
it wont care about load....
Next time i will use "m-stop"
http://motogadget.com/en/electrics/b...steuerung.html
it will automatic deactivate after 20sec
(no lights or buzzer necessary).
long distance greetings
Christoph
Christoph is offline   Reply With Quote
Old 03-11-2013, 06:41 PM   #18
afuncar
I just used a regular 6 volt 3 prong flasher and added 2 regular filament amber, bulbs in my engine compartment, works great.
afuncar is offline   Reply With Quote
Old 01-26-2016, 10:21 PM   #19
cfredona
I have a wiring diagram for a normal 3 pin thermal flasher for my turn signals but want to use LED's rather than bulbs. The Victor Auto Flasher EF32 mentioned below is a two pin flasher. How is this wired to the turn signal and what happens to the wire that normally goes to the third pin?
cfredona is offline   Reply With Quote
Old 01-26-2016, 11:59 PM   #20
daveymc29
daveymc29's Avatar
Bulb Toen $7.35 on sale, Victor EF32 Flasher
daveymc29 is offline   Reply With Quote
