04-18-2019, 07:03 PM | #1 |
Leaking Anti Freeze-Tips Ideas?
Thanks
thanks guys! Last edited by Bergy1; 05-14-2019 at 12:52 PM. |
04-18-2019, 07:43 PM | #2 |
Re: Leaking Anti Freeze-Tips Ideas?
Looks like you have got a good start. I have never had good luck with the stock style hose clamps.
Depends on where you are at for how much anti-freeze but 1½ gallons anti-freeze to 1½ gallons distilled water is a good start. I run 1 gallon anti-freeze to 2 gallons distilled water in the summer. Others will have their own opinions. |
04-18-2019, 07:52 PM | #3 |
Thanks for the ideas. I ordered the original style clamps
04-18-2019, 08:35 PM | #4 |
Pretty straight forward process to replace the lower metal pipe extension. Just be careful not to install it backwards as many have done.
I run 50/50 coolant to distilled water in mine all year long. I see no reason to do anything different than that. It will take close to three gallons of coolant to fill the system. No need to fill it all the way up to the filler neck as it will push quite a bit of it out the overflow tube. Just enough to cover the tubes is all that is really necessary.
Dave / Lincoln Nebraska |
04-18-2019, 08:51 PM | #5 |
Thanks Dave also! Great information!
04-18-2019, 09:17 PM | #6 |
