Old 02-14-2019, 12:45 PM   #1
fred93
fred93's Avatar
Default 29 Tudor windshield frame gasket questions
I am ready to install the gasket that goes on the bottom and two sides of the windshield frame. It seems that it can be installed in two different ways. I need to get feedback as to which way it goes.
Also, the side of the windshield frame has a screw & nut at the top of the frame. I assume that the rubber gasket needs to be notched out where the screw & nut are located. I also assume that the gasket needs to be notched out first, then it needs to be installed into the frame-THEN the screw & nut are installed?
Why is there never enough time to do it right, but always enough time to do it over!!!
fred93 is offline   Reply With Quote
Old 02-14-2019, 03:07 PM   #2
midgetracer
midgetracer's Avatar
Default Re: 29 Tudor windshield frame gasket questions
Your assumptions are right. The rubber also must be notched where the screw and nut goes through. notched then put in place, then the screw and nut installed.
midgetracer is offline   Reply With Quote
Old 02-14-2019, 03:18 PM   #3
fred93
fred93's Avatar
Here are more pix of the way I think it should be installed. Yes or No?
Old 02-14-2019, 03:29 PM   #4
Dave in MD
Fred,
You will need to cut a miter where the two side pieces meet the bottom piece. If you have stretched the rubber at all during instllation, let it relax a day or two before cutting the miter joint. You can use a dab of super glue on the miter joints to hold the side pieces to the bottom piece.
Dave
Dave in MD is offline   Reply With Quote
Old 02-14-2019, 05:19 PM   #5
fred93
fred93's Avatar
Thanks Dave--do the pictures look like I am correct with the way I am installing the gasket?
Old 02-14-2019, 05:22 PM   #6
fred93
fred93's Avatar
I have been playing with the gasket and I found that it is better to push the gasket into the frame channel rather than starting at one end and sliding it along. I started to install it by sliding into one end but by the time I got half way it wouldn't move any more.
Old 02-14-2019, 05:48 PM   #7
midgetracer
Use a little lube like wd-40
Old 02-14-2019, 08:17 PM   #8
fred93
fred93's Avatar
I used soapy water just in case I need to glue the gasket to the frame. I know that I need to super glue the bottom corners as well. so I don't want oil on the rubber.
Old 02-16-2019, 10:21 AM   #9
Dave in MD
Fred,
The pictures like you are installing the rubber correctly.
Dave
Old 02-16-2019, 02:46 PM   #10
Joe K
Joe K's Avatar
IIRC, my kit came with a tube of glycerine which you use to liberally grease the bulb/channel.
The warning about doing the miters is apt. I let mine sit two days and set it out in the sun for at least one of those days. It was still shrinking on the 2nd day.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-16-2019, 10:30 PM   #11
fred93
fred93's Avatar
Thanks to everyone who replied to my post. I can always count on the Ford Barn family to help me out.
