03-24-2018, 03:19 PM | #1 |
Engine Evaluation for Dummies
I am wondering how/if a novice can evaluate the basic components of a model A engine while it is still in the car. Such as:
1. Does it have a high compression head? 2. Does it have babbit bearings? 3. Does it have a balanced crank? Not sure I'm man enough to start pulling it all apart. |
03-24-2018, 03:36 PM | #2 |
Re: Engine Evaluation for Dummies
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 03-24-2018 at 07:21 PM. |
03-24-2018, 03:51 PM | #3 |
the hi comp head probably has cast marks you can see, the internals will probably need a boroscope to see
03-24-2018, 05:17 PM | #4 |
The high compression head can be checked by doing a compression check. A standard Model A head will have compression around 60 PSI. The police head will be 70-75 and the 5.5/6.0 HC head should be 90 to 100 PSI.
AL in NY |
03-24-2018, 05:59 PM | #5 |
The synders high compression heads look stock on top
03-24-2018, 06:06 PM | #6 |
03-24-2018, 06:40 PM | #7 | |
Other people already commented about pulling the pan to check the bearings and crankshaft. That's a good idea. You can give everything a good inspection while you're in there. Its not complicated to drop the pan, but you should read up about it first, especially regarding the oil pump.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
03-25-2018, 11:44 PM | #8 |
03-26-2018, 06:34 AM | #9 |
I think a compression test will tell you whether it has a high compression head. A peek in the sump with a bore scope should tell you about a balanced crank but only dropping the sump and removing a cap will tell you about the bearings.
03-26-2018, 07:34 AM | #10 |
I am assuming your car is running OK.
Why would you want to start dismantling the engine if you don’t have a problem. If a doctor wanted to cut you open and check thinks out, even if you were feeling great. What would you say. Having said that. I would recommend removing the oil pan on a car that is new to you. Clean it and clean and/or rebuild oil pump. I would not want you messing around with anything else under there unless you really know what your doing. Be careful putting pan back on. Oil pump needs to be attached in place first. There’s a nut on side of engine that will hold it in place. A stock Model A Ford engine, that is well taken care of, will outlast most of us. Last edited by WHN; 03-26-2018 at 01:08 PM. |
03-26-2018, 07:54 AM | #11 |
If it is running good what difference does it make if it has babbitt or inserts. They both do the same job. If they are bad you will know by the noise they make.
03-26-2018, 09:50 AM | #12 |
Last edited by Benson; 03-26-2018 at 02:31 PM. Reason: Several corrections and additions |
03-26-2018, 10:05 AM | #13 |
03-26-2018, 10:40 AM | #14 |
Is it FREE
Connoisseur of Rust |
03-26-2018, 11:58 AM | #15 |
The doctor analogy got me.....
03-27-2018, 02:58 PM | #16 |
I'd recommend driving it as it was born. Simple yet unique by today's standards. Best learning situation ever. An un-modified A will offer enough challenges to keep any new comer busy and challenged for years to come.
