09-25-2015, 12:08 PM | #21 | |
Re: No not urine just piss poor gas!
EPA doesn't want people to think about these things. They are too busy creating a boogey man to worry the masses and protect their phoney baloney Gov-mint jobs. |
09-25-2015, 12:18 PM | #22 |
I never use ethanol, pure gas only, I'm lucky my State still has it,
Any old gas I end up with I use to start my burn piles, or use to clean up 600W when I spill it on the floor.
09-25-2015, 12:38 PM | #23 |
My horror story with ethanol gas concerns my 65 Mustang FB that I am restoring. Been working on it for years and in 2009 had it all done except for paint, other projects came along and I placed it on one of my 4 post lifts with a hot rod parked under it. This summer I sold my '67 mustang and with floor space open I decided to finish my '65. Been sitting for 6 years it had 1/4 tank of gas. before I started the car I smelled the gas, didn't smell too good. The new gas tank I put in in 2009 had a drain so out came the gas, it was in bad shape, pulled the filler neck off and looked in the tank which was rusty. Pulled the tank and the fuel gauge which was rusted almost in two, the brass float was destroyed. The gas had Stabul put in it when placed on the lift but 6 years must have been too long with the crap that they sell for gas, new tank, and this time a SS gauge and 140.00 lighter in the pocket and I'm good to go. I only use non-ethanol gas in my classic/antique cars and small engines but in 2009 it was not available here in VA. Next time for long term storage all the gas will come out, and the engine will be run until it dies from lack of gas. As to the old gas, I live on a farm and it works great to start brush piles on fire, but as said, be careful it is still gas! Your mileage may vary...
09-25-2015, 01:29 PM | #24 |
i wouldnt put the old crap in my modern car and would not recommend anyone else to do it either...
09-25-2015, 01:44 PM | #25 | |
I also use it to clean parts, then start fires in my outdoor fire pit after it's too dirty. I try to keep the gas off my skin as I clean parts, because it's bad stuff, unlike the gas of the 60's. |
09-25-2015, 01:57 PM | #26 | |
Blackwall Panthers Nor Cal chapter |
09-25-2015, 02:17 PM | #27 |
holdover- I'm told StaBil has a shelf life too.
Boat guys tell me Startron is the best or fill up w/ aviation gas in the fall before storage. Sunoco Racing Gas good to use too. |
09-25-2015, 02:23 PM | #28 |
We have the same problem with our boats. I just brought 30 gallons to the town dump so they can dispose of it. Ethanol absorbs water and turns it into a thick substance that settles to the bottom and screws up every thing.
09-25-2015, 02:33 PM | #29 | |
its great for business,, electric fuel pumps, injectors etc etc |
09-25-2015, 03:33 PM | #30 |
SAD THING, at a show, saw a high points car struggling to start, when it finally started, it REAKED with the smell of OLD VARNISHED UP FUEL!!
If you ever worked in a Wrecking Yard, you KNOW that SMELL---It takes 3 days to get that smell off your hands! Whether you're a High Points owner or a regular Model A guy, we can ALL learn from each other. Bill W.
09-25-2015, 04:19 PM | #31 |
The basic problem with ethanol is that it is hygroscopic, meaning it attracts water. Generally, water in a carb or internal combustion chamber is not desirable. Modern ethanol-contaminated gasoline reduces your mileage by 10% and comprises usually 10% of the volume of a gallon of gas. Where's the logic? Oh, no logic, just make sure those agri-businesses that have those ethanol distilleries get a "satisfactory" profit.
09-25-2015, 04:30 PM | #32 |
I've had no problem. I fill both cars up and add Sea foam and MMO. In the spring start 'em both up and go. The AA is choke, two turns and fire.
The T is persnickety but it fires. Lucky I guess.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
