03-05-2012, 02:33 PM | #1 |
winfield head use...
Anyone using aluminum Winfield 8.5:1 head on their engine? I'm researching buying one and would appreciate any input into pros/cons of using such and what head gasket recommended?
03-05-2012, 05:25 PM | #2 |
Re: winfield head use...
I have a Winfield "Crowsfoot", 8.5:1 on a modified Diamond "B". Wasn't impressed with power out-put compared to a Police head or a Winfield Super. Felt it was time to make some more modifications. I machined relief radii in combustion chambers to reduce shrouding of the intake valves. CC'd the combustion chambers and had a engine machine shop fly-cut the head to obtain 8.5:1 CR. Still wasn't satisfied with power and RPM's so I designed and machined Offset Valve Guides to move the intake valves .080 towards the pistons. Very impressed with over-all preformance. I will PM you with drawings and pictures.
Jerry |
03-05-2012, 05:30 PM | #3 |
to much compression for the average banger . be carefull or the rods will be on the ground !
V4f |
03-05-2012, 08:28 PM | #4 | |
Not in this B ! Look up 'Crower' produced B rods. There's a reason they are called 'bullet proof' And, they are in a bullet proof Russian B (full pressure/inserts).. And , sounds like with a little 'help from my friends' (huntington beach) we're going to 'wake that puppy up! Last edited by hardtimes; 03-05-2012 at 08:29 PM. Reason: .. |
03-05-2012, 08:36 PM | #5 | |
03-05-2012, 10:18 PM | #6 |
Steve |
03-05-2012, 10:26 PM | #7 |
I think he meant he had it resurfaced to regain the 8.5 CR after he increased the chamber CC's by unshrouding the valves.
03-05-2012, 11:11 PM | #8 |
Hello Hartimes,
I modified '39 Pontiac rods for inserts. Have a drawing if you are interested. Jerry |
03-06-2012, 12:52 AM | #9 | |
I'm very interested in your work, both winfield head alterations and rod useage. I sent you a message with my email. Thanks! I've got a friend who is also innovative like you. He is making Aluminum rods for the B engine, very strong...similar to what is used in high rpm race engines. |
03-06-2012, 12:07 PM | #10 |
SteveB31, the original aluminum Super Winfield head was a good one, just be sure that water hasn't corroded it too much to be run.
