Old 08-12-2017, 04:30 PM   #1
dahrens1
Default Is this Wheel/Lug Nut Safe to use?
In the MARC "Technically Speaking" Volume 10 pg. 18 it describes a problem caused by some reproduction lug nuts that do not have the 3/32" thread relief at the base of the lug nut as required in the original Ford specs. This was also described, I believe, on pg. 7 of the March/April 1988 issue of The Restorer magazine. The article in this link also discusses this: http://www.fordgarage.com/pages/dangerouslugnuts.htm
In the picture below the lug nut on the left (might be an original lug nut) has the required 3/32" thread relief. The lug nut on the right is a new stainless steel reproduction lug nut purchased recently from one of the vendors. As you can see it does not have much of a thread relief at all, at most 1/32" and at one point 0.0" thread relief.
So my question is is it safe to use or could it cause problems with thread torque and possible loose wheels over time?
Thanks
Dave
dahrens1 is offline   Reply With Quote
Old 08-12-2017, 05:01 PM   #2
Drive Shaft Dave
Default Re: Is this Wheel/Lug Nut Safe to use?
The one on the right I would not use. When tightening that lug nut with a possibly sloppy wheel hub hole ,the lack of relief would cause the nut to tighten down to the drum leaving the tapered part of the nut loose on hub of the wheel. I think one of national clubs magazine describes this in detail. The article in Ford Garage says it all.
Drive Shaft Dave is offline   Reply With Quote
Old 08-12-2017, 05:22 PM   #3
WHN
The vendors sell a washer that is designed to be used with lug nuts.
I think that would take care of your concerns.
We put them on all our cars. No problems and protects paint.
WHN is online now   Reply With Quote
Old 08-13-2017, 01:48 AM   #4
Dollar Bill
Dollar Bill's Avatar
+1 for the S/S lug nuts and washers.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 08-13-2017, 03:40 AM   #5
johnbuckley
johnbuckley's Avatar
Originally Posted by Drive Shaft Dave View Post
The one on the right I would not use. ...l.
Just to show we're all different the one on the right IS the one I'd use! I'm always apprehensive that wheel nuts may bottom out onto the hub before they grab onto the wheel, if the hole of the wheel is worn. The flatted off one on the right strikes me as a better design.
Old 08-13-2017, 07:02 AM   #6
jm29henry
jm29henry's Avatar
Iug # 1 gets my vote !!!
jm29henry is offline   Reply With Quote
Old 08-13-2017, 08:00 AM   #7
Roger V
Roger V's Avatar
The relief is for the shoulder on the lug bolt as its threads don't go all the way to the hub. Therefore, the lug nut on the right hand side stops before it can get to the hub or tighten against the wheel's lug hole. Worn or "wallered-out" (not a word) lug holes in a wheel are another issue and why the lug washers were invented.
Roger V is offline   Reply With Quote
Old 08-13-2017, 08:12 AM   #8
V4F
V4F's Avatar
use "wheel savers" ........... helps the wheels from wallowing .
**The vendors sell a washer that is designed to be used with lug nuts.
V4f
V4F is offline   Reply With Quote
Old 08-13-2017, 08:30 AM   #9
Afordman31
Afordman31's Avatar
When I buy a Model A wheel I take a lug nut with me and check the holes for wear. I put the nut in its place and check to see that it doesn't extend out on the backside. If it falls short that would be the one that I would buy!
Afordman31 is offline   Reply With Quote
Old 08-14-2017, 05:03 AM   #10
RUNNERBUN
RUNNERBUN's Avatar
Using the one on the right is possible but I would use the washer. If you have a lathe or a friend with one I would suggest you can cut the relief as well. Should be a straight forward job.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 08-14-2017, 09:06 AM   #11
captndan
captndan's Avatar
Use the correct ones to begin with. I have never heard of a wheel falling off because of incorrect lug nuts.
captndan is offline   Reply With Quote
