03-23-2013, 07:38 PM | #1 |
Camshaft question
Does anyone know what the height measurement of the camshaft lobes were originally? I know this probably isn't the best way to check a camshaft, but it is pretty easy to get a quick idea if the cam is worn very much. I have seen the diameter of the bearings (1.56") in books, but not the total height of the lobs. This can be easily be checked with a caliper. If anyone knows what this dimension is, would you please post it here.
Rusty Nelson Last edited by wrndln; 03-23-2013 at 10:30 PM. |
03-23-2013, 08:05 PM | #2 |
Re: Camshaft question
Here is a link with the lift specks, but it looks like they are taken from the center of the camshaft .779 to the high point of cam from center, .302 for the lift. as far as I can figure 1.256 bottom of round to high point of cam.
Center to top is .779 w/lift, so i subtract .302 the lift, from .779 is= .477 to 1/2 dia of cam. Now .477 Twice= .954 + .302 = 1.256 Maybe you can determine something from the drawings, to use with your caliper, to get the sum you want to measure overall from bottom to top??? http://www.fordgarage.com/pages/camshaftspecs.htm Last edited by Jazzjr; 03-23-2013 at 08:34 PM. |
03-23-2013, 10:10 PM | #3 |
Bill Stipe told me for best results the center bearing needs to be 1.557. The center bearing was originally 1.560 The lobe height should be preferably not less than 1.225 This is the numbers that I looked for when I measured lots of cams before I found one that met these specs. We had our cam ground to the popular Super street Winfield 3/4 race. It idles good and coupled with a 5.9 head it gives better performance accross the rpm range . I think the lift is 314 . the original lift has been said to be 302 . Most cam grinders will grind what you send them. A center bearing diameter of 1.556 isn.t too bad but it gives the cam more room to rattle around in the block .
03-24-2013, 01:56 AM | #4 |
Rusty, Vince has the information you want. I just compared it to my NOS camshaft and it's right on.
http://www.fordgarage.com/pages/camshaftspecs.htm |
03-24-2013, 09:33 AM | #5 | |
Ummm, depending on the quality of the caliper, do not be alarmed if your camshaft does not match the specs on the print. You really need to use a micrometer instead if you are trying to make an accurate assessment as your calipers may be off as much as .002 - .004 and give you a false reading with regard to wear. |
03-24-2013, 12:44 PM | #6 |
Rusty Nelson |
03-24-2013, 02:15 PM | #7 | |
A or B...they are different..no? |
