Old 01-12-2018, 11:38 PM   #1
wingski
wingski's Avatar
Default removing instrument panel
I’ve looked in all my manuals and can’t find instructions for removal of an instrument panel on a ’29. Can anyone point me in the right direction?
Mike
wingski is offline   Reply With Quote
Old 01-13-2018, 12:34 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: removing instrument panel
The silver thing with the instruments? Four screws and its out. The Dash panel that goes from door to door is a little different even between open and closed cars but I think there are only 6 screws.
Old 01-13-2018, 12:50 AM   #3
3.6rs
3.6rs's Avatar
Mike
Two pictures that say more then words
3.6rs is offline   Reply With Quote
Old 01-13-2018, 01:47 AM   #4
wingski
wingski's Avatar
The reason I asked is because I think that fuel guage is hooked directly to the fuel tank since it isn’t electrical. Am I wrong, isn’t there a rod that goes directly from the guage to the float in the tank or can that thing be easily disconnected? I’ve heard nothing but horror stories about removing the face on the fuel guage and that it takes a special tool to remove it.
It would be nice to be able to find a diagram to see what the back of the instrument panel looks like.
I don’t think I’ve ever removed one. If I have, I sure don’t remember it.
Mike
Old 01-13-2018, 01:59 AM   #5
Bill G
Bill G's Avatar
The gas gauge is separate. When you take the dash panel off, it just surrounds the gas gauge and the gauge stays on the tank. That way you can get to the ignition switch, the speedometer, the dash light and the ammeter without disturbing the gas gauge. The gas tank gauge requires an empty tank and a special tool to remove the chrome rosette surrounding the gauge.
You are correct that the float and indicator are mechanical. There is nothing electrical about that gauge.
If it isn't leaking or if it registers reasonably, and if you have no real reason to remove the gas gauge, I would advise against messing with that.
The other parts are easy. 4 screws, like others have said.
Bill G is online now   Reply With Quote
Old 01-13-2018, 03:38 AM   #6
slammin
slammin's Avatar
Mike,
Its best to disconnect the battery before removing the instrument panel.
slammin is offline   Reply With Quote
Old 01-13-2018, 06:13 AM   #7
Dollar Bill
Dollar Bill's Avatar
Not a diagram but photo of back side to give you an idea of what you're up against.
Like Magicbox stated, the fuel gauge is mounted to the tank and is separate from the instrument panel.
Also a great recommendation to disconnect the battery cable.
Pixs is of later model but attaches in the same fashion as yours.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 01-13-2018, 08:13 AM   #8
CT Jack
CT Jack's Avatar
Curious, what are you trying to do? Do you want to see how things work or are you trying to fix something such as the fuel sight glass, guage, or a gauge leak. The fuel gauge sight glass is sealed with gaskets that are screwed into the fuel tank. When you see the liquid inside the fuel gauge that is gasoline. If you have a need to remove the sight glass or the gauge completely drain the fuel tank and disconnect the battery as mentioned in previous threads.
CT Jack is offline   Reply With Quote
Old 01-13-2018, 09:44 AM   #9
Anteek29
Anteek29's Avatar
Wow...did not realize how basic things were behind that little panel
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 01-13-2018, 12:02 PM   #10
To_Lolo52
Yes indeed special tools need to remove the gas gauge. Two tools available. Your choice of sellers online. Do not repeat do not try and use anything other than the special tools (two each) one to hold outer nut, one to hold inner star shaped gauge. View Richpins video on Youtube on how to adjust level of float arm.
Sent from my SM-G935P using Tapatalk
To_Lolo52 is offline   Reply With Quote
Old 01-13-2018, 02:39 PM   #11
Gary WA
Gary WA's Avatar
This is a Must Have Tells All!
www.whidbeymodelaclub.com
Old 01-13-2018, 05:30 PM   #12
1930-Pickup
Good advice. Beginners to Master Mechanics use this book.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 01-14-2018, 01:08 AM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Be sure to use ONLY the cork gaskets.
Old 01-14-2018, 12:42 PM   #14
3.6rs
3.6rs's Avatar
Well, this is the tought of most of the forum users.
I bought the 3 books a few months ago but it's my most disapointed buy in years ! That is what I think about it of coarse...
Old 01-14-2018, 01:36 PM   #15
Ford1930
Ford1930's Avatar
Here some picture of the Instrument Panel (backside), the Dash without the IP and the parts of the gas gauge as they came off from my 180A.
Ford1930 is offline   Reply With Quote
Old 01-14-2018, 02:35 PM   #16
Chris Haynes
Chris Haynes's Avatar
The "Special Tool" is available through most Model A parts vendors. It is not expensive and is easy to use. Most likely someone in your local club has one.
The first time I filled the tank on my car I discovered the previous owner had assembled the gauge without gaskets.
1921 Runabout
1930 Tudor
Early 1930 AA
