Old 11-14-2018, 09:10 AM   #1
jhowes
Default Lifters
How do I remove the lifters so that I can replace the cam and put in adjustable lifters? In tried to pull them up now that the valves and springs, etc. are not in the way, but they did not come out all the way. Is there something holding them in? Jack
jhowes is offline   Reply With Quote
Old 11-14-2018, 09:16 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Lifters
They must come out of the bottom. You will need to use clothes pins or something similar to hold them up during the camshaft removal process if you cannot invert the engine.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-14-2018, 11:27 AM   #3
jhowes
Default Re: Lifters
Thanks Brent, I appreciate the information. Jack
