07-30-2020, 02:43 PM | #1 |
Voltage Regulator??
Anyone use a voltage regulator in their Model A?? If so what regulator and why? I am replacing the wiring harness and the awful wiring job on my 30 Coupe. It has a lot of stuff wired to a voltage regulator n the firewall and I’m wondering if that needs to be there.
07-30-2020, 02:52 PM | #2 |
Re: Voltage Regulator??
What generator are you running, two brush or three?
How about a picture. |
07-30-2020, 03:34 PM | #3 |
It sounds like you're using a later style 2 brush generator. If so, then a regulator needs to be mounted somewhere.
If you want to install an original type 3 brush generator then you don't need a regulator, just a cutout. |
07-30-2020, 04:33 PM | #4 |
I use the Fun Projects voltage regulator that takes the place of the cut out . The original cut out doesn't give voltage regulation .
07-30-2020, 08:10 PM | #5 |
Three brush delco remy uses a 2 point regulator which functions like a cut out and the 2 brush uses the 3 point regulator. Tractors used the same set up and there are documents and videos on line that show how it connects.
07-30-2020, 08:34 PM | #6 |
07-30-2020, 09:04 PM | #7 |
07-30-2020, 10:29 PM | #8 |
I use Tom Wesenberg voltage reg, his is fool proof ,if the generator should go open circuit the voltage will remain low, not going into a self destruct high voltage runaway.
07-31-2020, 08:20 AM | #9 |
