Old 05-20-2020, 04:14 PM   #1
neds29
Default Kelsey-Hayes rims on new cast iron
I've installed cast iron rear drums but now my K-H rims won't fit. It seems that the new emergency/parking brake casting is larger than original. Has anybody else encountered this? What is your solution? I've been grinding the welds where the spokes join the rims, but they still won't fit. Is there an "easy" solution? Thanks. Ned
Retired civil engineer.
Winters in Phoenix, summers in Ipswich, Mass. and North Dakota.
'29 closed cab pickup- Excellent AZ truck.
'29 roadster- Owned for 21 years but now sold.
'28 CC pickup- My first car in Andover, MA back in '62- '63.
neds29 is offline   Reply With Quote
Old 05-20-2020, 05:23 PM   #2
CarlG
CarlG's Avatar
Default Re: Kelsey-Hayes rims on new cast iron
Whose drums did you use?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-20-2020, 05:37 PM   #3
Charlie Stephens
It won't solve the problem but might give more data, will an original Model A rim fit?
Charlie Stephens
Old 05-20-2020, 06:16 PM   #4
Gary WA
Gary WA's Avatar
Early Ford Wire Wheel Tech - Hot Rod Forum : Hotrodders Bulletin Board
www.whidbeymodelaclub.com
Old 05-20-2020, 06:31 PM   #5
SteveB31
SteveB31's Avatar
You can only use Kelsey Hayes wheel on rear cast drums by grinding the heck out of the inner spoke ends to clear the drum. Not a cool thing to do, but if you are careful it will work.
SteveB31 is offline   Reply With Quote
Old 05-20-2020, 07:24 PM   #6
CA Victoria
CA Victoria's Avatar
Bummer eh, I had 5 KH bent spokes power coated before I checked them on the 4 original Ford cast iron drums. No bueno-would not fit over rear drums.
I was not comfortable with grinding the spokes.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 05-20-2020, 11:27 PM   #7
lildave
lildave's Avatar
I have a 31 Vicky sitting on Kelsey Hayes, I haven’t looked to see if anything was modified. Parked for 50+years. I’m told 1 is missing. I can try to get a picture.
lildave is offline   Reply With Quote
Old 05-21-2020, 07:13 AM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Steve, how much interference is there? Can/could the drum itself be machined on the outside some to gain the necessary clearance?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-23-2020, 08:31 PM   #9
lildave
lildave's Avatar
Model a ford mechanics handbookvII page 4-18
Old 05-23-2020, 08:40 PM   #10
Charlie Stephens
I think I would call Randy Gross and ask him if the drums he sells clear, 714-292-8660 or email [email protected]. If so, send the ones you have back and buy from him.
Charlie Stephens
Old 06-20-2020, 11:19 PM   #11
lildave
lildave's Avatar
Old 06-21-2020, 04:05 AM   #12
Bruce of MN
Bruce of MN's Avatar
Rotated:
Bruce of MN is offline   Reply With Quote
Old 06-21-2020, 04:05 AM   #13
Bruce of MN
Rotated:
Old 06-28-2020, 08:42 AM   #14
neds29
I solved it by grinding the "bump" of the spoke welds. Not a great idea but it works. Was a real pain to do. Then painted over the grind marks.
Wish I'd have known of the problem earlier as the drums could have been truned.
Ned
