05-26-2020, 02:25 PM | #1 |
Who owns a floor vent, manifold heater?
I saved these pictures, several years ago.
I don't remember whose car it was. Do any of own a vehicle with a floor vent, manifold heater? I have everything but the manifold cover. |
05-26-2020, 07:18 PM | #2 |
Re: Who owns a floor vent, manifold heater?
I have a Arvin cover for one but they came in many configurations. So not sure if it would fit your application..
Wanted flathead speed equipment Thanks |
05-26-2020, 07:23 PM | #3 |
Neil I don`t have one like that but I have been lucky enough to find two floor vent type as pictured. I put one in my 160 A and it will run you out of there. i like having the vent go through in the wood, so no hole in the firewall. I have a flier on this manifold somewhere here but there is no brand name on it.
05-27-2020, 09:53 AM | #4 |
[QUOTEI have everything but the manifold cover.][/QUOTE]
If you have the manifold it shouldn't be hard to fabricate a cover.
05-27-2020, 02:43 PM | #5 |
I have a stock manifold, so I need to fabricate a cover that will sit on the manifold and connect to the pieces coming up from the floor.
05-27-2020, 07:12 PM | #6 |
05-27-2020, 07:17 PM | #7 |
Backside of cover. Also I believe a fellow Fordbarn member worked at the factory and may have more inside info on the heater vent Neil has and this cover..
05-28-2020, 09:59 AM | #8 |
The photo shows a reproduction of a hot air floor heater that is in my Coupe. It has poor air flow, so not much heat gets into the car. I will be adding an electric fan into the system to force air flow.
Bob Bidonde |
05-28-2020, 10:40 AM | #9 |
[QUOTEI] have a stock manifold,[/QUOTE]
A lot of the "manifold heaters" used a special exhaust manifold, some w/fins, to radiate heat. In your first post you said "I have everything but the manifold cover." so I assumed that you had an aftermarket manifold.
05-28-2020, 01:17 PM | #10 |
Hop up,
I would like to buy your Arvin cover. I sent you a PM. |
