07-21-2014, 05:47 PM | #1 |
flat top pistons
What is better flat top pistons or dome pistons as far as performance goes amd why
07-21-2014, 06:28 PM | #2 |
Re: flat top pistons
Domers for raised compression and a little more power.
07-22-2014, 12:27 AM | #3 |
the third best is a set of flat tops (slight dome) with .080 to .125 taken off an early head. the fourth is .080 to .125 taken off a late model head. (use thick washers under the head bolt if you mill the head) the fifth is flat tops with an early head and lastly flat tops with a late head. Oh and you can use the dome piston and take .080 off the head. |
