Old 03-20-2018, 05:01 AM   #1
woofa.express
woofa.express's Avatar
Default 28 pickup rear spring
goodday people.
my 28 pickup gives a hard ride. I renewed shockers with post manufactured. no improvement. this vehicle will never carry more than 2 hundred weight.
question. has anyone had experience with removing leaf springs to a bare minimum.?
the vehicle is named "woofa express". woofa is the good looking hound guarding the pickup and tourer behind. you call a tourer a Phaeton.
Last edited by woofa.express; 03-20-2018 at 05:03 AM. Reason: needed a further explanation
woofa.express is offline   Reply With Quote
Old 03-20-2018, 05:08 AM   #2
brokenspoke
Default Re: 28 pickup rear spring
I used a 7 leaf roadster spring in the rear of my RPU
brokenspoke is offline   Reply With Quote
Old 03-20-2018, 05:22 AM   #3
woofa.express
thankyou Broken Spoke. would you suggest I simply remove maybe one or two leaves? it is the improved ride I am after.
I live in Australia and unlike you in America we don't have such a ready supply of parts. thanks again for your info. gary
Last edited by woofa.express; 03-20-2018 at 05:24 AM. Reason: upgrading requirement
Old 03-20-2018, 06:22 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Make sure you have lubrication between each spring leaf. I use grease, then sprinkle powdered graphite over the grease, assemble the spring, and wrap it with spring covers.
Old 03-20-2018, 06:25 AM   #5
cjkohnast
You need to change the saddle that goes on above the nuts to make up for the smaller spring
cjkohnast is offline   Reply With Quote
Old 03-20-2018, 08:44 AM   #6
Corley
Note that if you remove leaves, and go too far, the spring flexes more with the effect of getting longer. Since it is now riding further out and down on the shakles, the rig may have more tendency to rock and roll on corners. More lean can happen more easily as the vehicle swings around on the shakes.
(Sorry, I have spelled shakles two different ways, and neither looks right. At 78 spelling is not my strong point, in fact some wonder if I even have one.)
Corley is offline   Reply With Quote
Old 03-20-2018, 08:52 AM   #7
wrndln
I have a 29 CCPU. I plan to do what was mentioned above, remove leaf 7 and 9 to make an 8 leaf spring from a 10 leaf spring. This is how Ford made 8 leaf springs - deleted leaf 7 and 9. Pickups originally had 10 leaf springs as they were setup to carry heavier loads back in the day. Ford used 8 leaf springs on phaetons and coupes, so I see no reason an 8 leaf spring on a pickup would be a problem. I think the ride should be better. Yes, you do need to use the 7 - 8 leaf spring U bolt retainer plates, if you go to an 8 leaf spring.
Rusty Nelson
Old 03-20-2018, 08:54 AM   #8
Ray64
Ray64's Avatar
lol
Ray64 is offline   Reply With Quote
Old 03-20-2018, 01:55 PM   #9
1930-Pickup
Rusty Nelson
I agree with Rusty. This is exactly what I plan to do with my 1930 CCPU.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 03-20-2018, 03:17 PM   #10
woofa.express
thankyou all. It is great to ask for help and receive opinions from those who know and are generous to share it. I see that Corley is a junior member at 78! I too are like you Corley, junior that is, and I hope I'm driving mine at 78. eight to catch up but you will be 86 then. cheers, gary
Old 03-20-2018, 04:39 PM   #11
Synchro909
Synchro909's Avatar
For my current project (a ute), I am making a rear spring out of 2 old ones. Both have broken leaves and I can't get a 10 leaf spring out of them without shortening one so I'll settle for 9 leaves.
From this thread, I'm even more hopeful than before that it will be OK - maybe even a bit hard but there will be times when it carries a bit of a load. A reasonable compromise, I think.
Old 03-20-2018, 04:45 PM   #12
1955cj5
1955cj5's Avatar
Post #26 in this thread has some measurements that Tom W. made of an 8 leaf pack and also of my 13 leaf pack(talk about a stiff ride!) that I reduced to an 8 leaf.
https://www.fordbarn.com/forum/showt...=182182&page=2
Huge improvement in ride.
I sorta wish I'd a made a 9 leaf pack as the old leaves are, well, old and one more leaf might have lifted the rear just a little to give that pickup truck look....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 03-20-2018, 06:00 PM   #13
walls
Be careful taking your spring apart and reassembling it, if you’ve never done it.
You should absolutely read up on that.
Removing 2 or 3 springs is ok, but will lower your car a bit.
You also have to remove the correct ones.
I’d keep the main and 2nd then remove every other one.
Whichever leaves you removed, then must be cut down and installed under the spring pack, so the bolts will tighten up properly.
walls is offline   Reply With Quote
Old 03-20-2018, 11:57 PM   #14
woofa.express
will I see you in Murray Bridge with the ute?
Old 03-20-2018, 11:58 PM   #15
woofa.express
I've messed up this thread. it's all new to me. g
Old 03-21-2018, 12:02 AM   #16
woofa.express
I've messed up this thread. this is all new to me
Old 03-21-2018, 02:53 AM   #17
Synchro909
Synchro909's Avatar
No, not this one. It won't be ready by then. We've got another rally and a trip to the US to fit in between now and then. Haven't decided which car to take yet.
Old 03-21-2018, 05:57 AM   #18
Clem Clement
Clem Clement's Avatar
One time I was tasked to get the beer for a party. Two pony kegs set my 29 pickup just right. nice bounce. I almost cancelled the party and kept the kegs...nah!
Old 03-21-2018, 08:04 AM   #19
Jim M
Jim M's Avatar
Just rebuilt my rear spring on my 29 Roadster. I got a couple of great hints from my local club. First take a grinder and slightly grind of the very tip edges of the bottom of each leaf so they don't have a tendency over time to gouge the leaf below them (as mine had done), Second I found a product called SLIP spray on graphite. After I sand blasted and primed the leafs I sprayed the SLIP on. Watched a fly break it's neck trying to land on it........lol.
Jim M is offline   Reply With Quote
Old 03-21-2018, 09:00 AM   #20
katy
katy's Avatar
Try: shackles
