02-27-2017, 07:30 PM | #1 |
Engine stand advice
Anyone have one of these? Its supposed to be able to take 1250lbs. I would like something a bit more solid but I cant get anything reasonably priced over here , If I order through Ebay delivery is expensive . This one is $130 delivered.. What else should I be aware of as Im not sure if the Flathead likes to be mounted in the conventional way....?
02-27-2017, 07:52 PM | #2 |
Re: Engine stand advice
Depends on the year, 8ba blocks can mount like an OHV. 59a and early should mount from the side which requires a specially designed adaptor.
02-27-2017, 07:54 PM | #3 |
It will be for a 37 ..with bellhousing.
02-27-2017, 07:57 PM | #4 |
Search this Forum, you'll find lots of discussion, like thisl
https://www.fordbarn.com/forum/showth...d+engine+stand |
02-27-2017, 08:04 PM | #5 |
This is the way to mount the early blocks. Ed
02-27-2017, 08:05 PM | #6 |
02-27-2017, 08:16 PM | #7 |
Couple of examples.
02-27-2017, 08:20 PM | #8 |
jseery, is that a triumph or a norton to the left there of that flathead?
02-27-2017, 08:59 PM | #9 |
I stole the photo, it's not mine!
I was going to add, if you can weld it is easy to weld one up. You can use an exhaust gasket for the bolt pattern. Last edited by JSeery; 02-27-2017 at 11:34 PM. |
02-27-2017, 09:02 PM | #10 | |
Crude, but it works and it is safe.
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
02-27-2017, 09:11 PM | #11 |
Mmmm looks like I have to make something!
But the stand overall ok ?
02-27-2017, 09:52 PM | #12 |
I like the stand a lot. Specially for the price, and it has 4 wheels. Mine has a 3 wheel configuration and it's spooky moving it with an engine on it. As for the motorcycle I'm gonna guess '68 or later (because of the square barrel) 441 BSA shooting star.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
02-28-2017, 01:48 AM | #13 |
02-28-2017, 02:16 AM | #14 |
Stand looks just fine 4 wheel is prefered i buy mine from the swedish version of HF.
Adapter is made from whatever 10mm or thicker that comes in my way. Old exhaust manifold as drill pattern for the 4 holes needed, make all 4 holes larger size if you want it to go either side of engine. Tube cut 45 and then welded togetter |
02-28-2017, 03:23 AM | #15 |
Cool!
02-28-2017, 08:07 AM | #16 |
Those stands will handle a flathead Ford, just don't put a Flathead Cadillac or early Hemi on one . . . then they tend to make me a bit nervous!
As noted - make a good exhaust bolt hanger - and make the bolt holes 7/16+. |
02-28-2017, 08:36 AM | #17 |
I have a stand that looks very similar to the one in the original post, but I made my own adapter that bolts to the exhaust ports, and allows the mounting angle to change when the block/complete engine is flipped over. If I had used the adapter with pipe welded to mounting plate, the engine would have been at some awkward angle when flipped over. Also, with the bolt together design, I can bolt that adapter together in a different configuration to fit the other side of the block w/o having extra holes in the mounting plate. It also allows for mounting to all six exhaust manifold bolt holes, while the pipe welded to center design will not.
I really don't trust using some of those three legged stands. They are very easy to tip over . I added a few more pics of a '36 LB engine on that same stand that I didn't know was an LB until I removed the oil pan, measured the main bearing stud center to center distance, and removed the cap. I was a very happy camper to find out this engine had loose/large main bearings .
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-28-2017 at 11:24 AM. |
02-28-2017, 10:04 AM | #18 |
Some of these adaptors use (4) bolts, the ones with the pipe welded in the middle. The ones with the flat plate use (6). Any thoughts on best method?..... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
02-28-2017, 10:38 AM | #19 | |
02-28-2017, 10:50 AM | #20 |
The stand looks fine, but one thing to thing about. If you are using a cherry picker can you get to the engine with it? The width may be an issue. Gary
I am usually relatively happy------Gary |
