I need several of the female "t" shaped inserts that are in the roof channel that the brackets that hold the wooden cross pieces bolt to in a '35 Ford. I imagine that these are the same for all body styles. These pieces are flat in top and lay flush with the surface of the bottom of the channel. Perpendicular to the flat piece is a threaded cylinder which sticks down, through the channel and a bolt screws into that, holding the wood bracket. I could probably use six, but I will take what I can get. They are soldered to the bottom of the channel but could be easily unsoldered. Thanks.
[email protected]
