08-08-2019, 11:37 AM | #1 |
32 stock tudor shortened pitman arm
anyone making shortened pitman arms for 32 stock ford ?? any qualified welders in calif area that can cut and weld this ? seems easier than changing out box gears for hard steering..etc. sc
08-08-2019, 12:38 PM | #2 |
Re: 32 stock tudor shortened pitman arm
Whomever told you that shortening the pitman arm would lessen the steering effort either flunked physics or fell asleep during the part about leverage.
08-08-2019, 12:50 PM | #3 |
It’s done on Model A’s all the time and makes a big difference, why wouldn’t it work on a 32?
08-08-2019, 01:11 PM | #4 |
What size tires are you running?? If you jack the front end up does it "steer" eassy?? Is everything (king pins, tie rod ends, etc lubricated well?? Lubricant in the "box"??
Paul in CT My 32 4dr sedan had no steering issues. |
08-08-2019, 02:57 PM | #5 |
A shorter arm will give quicker steering , but do you really need heavier steering as this will be the result . Plus the change in geometry you may get bump steer also.
08-08-2019, 04:12 PM | #6 |
08-08-2019, 06:00 PM | #7 | |
Never mind I figured it out . Longer arm , less effort but more movement Last edited by Ggmac; 08-08-2019 at 06:37 PM. |
08-08-2019, 10:51 PM | #8 |
Seems to me that shorter arm will make it steer slower and easier..ask a model A guy they have been using them for years ? thought maybe someone was making these ....
08-09-2019, 06:30 AM | #9 |
The other trade off with a shorter arm is a significantly increased turning radius.
The ball stud on the end of a stock '32 pitman arm falls beneath the lower lip of the chassis and the end of the drag link connected to it is therefore even further inboard. With the stock arm and drag link, the drag link barely clears the frame lip in extreme right and left hand turns. Shorten the arm and the drag link will strike the frame lip. The shorter the arm, the sooner the drag link will strike the frame lip and limit the right and left hand turns. Think about it; is the trade off worth the restricted maneuverability? Last edited by DavidG; 08-09-2019 at 07:43 PM. |
08-09-2019, 07:25 PM | #10 |
Shortening a pitman arm is simple process for a certified TIG welder. Steering parts should be magnafluxed after rework. Even stock parts require it for racing in some classes like vintage midgets.
08-09-2019, 07:34 PM | #11 |
I found a fellow ( he found me)in Calif that can do this type of work..only problem is calculating how much to cut and drag link lenght..
08-10-2019, 06:49 PM | #12 |
Vern Tardel's book "Building a traditional Ford Hot Rod" does a great job of covering that topic. I followed his calculations, and was pleased with the steering effort, and turning radius.
08-10-2019, 06:56 PM | #13 |
David's point re the 32 arm positioning the drag link below the frame is very pertinent. While the logic of the idea is sound, (although some seem to be making statements the opposite of what would be true) the reality might be that the options are limited in a 32 due to the positioning of the drag link.
I believe the standard procedure is to use later parts to give the lower ratio which is completely undetectable visually. (15:1 rather than 13:1). Or put a Hudson, F1 or F100 in it. Or as in my 33, a 37 turned on it's side, filled with RHD guts. Mart. |
08-11-2019, 12:13 AM | #14 |
Mart,I'd be interested to see how you did your '33.Have any pics? Will work on LHD? Thanks
08-11-2019, 03:22 AM | #15 |
Sorry for thread Hi-Jack.
Deuce, Yeah, it's a LHD application. There's some info here: Mart's three month 33 5W Survivor project Some pics are missing due to PhotoBucket. I could put something together describing it with fresh pics, but not many people have both LHD and RHD parts to pick from. There is a sister thread here on the barn but I could not find it. Mart. |
08-12-2019, 12:23 AM | #16 |
I did some looking today at 32 drag link and pitman arm ..arm is about 5-1/2" c-c and a bit more..problem as i see it is the clearance to bottom of frame if pitman is shortened..I think the pitman will have to be turned around to face out so the drag will clear bottom of frame..also the drag link will have to be cut and turned 180 degrees..this is going to take some study..
08-12-2019, 01:30 AM | #17 | |
I've tig'ed some mech brake stuff with contingency. Tig would be best. I'm curious why this is a thing? on a stocker? Is it really needed? . |
08-12-2019, 10:31 AM | #18 |
I think that you are getting into quicksand. You may end up with a mess.
I put the 15-1 gears in my 32. It was better. I have an extra box with nos 15-1 gears. You need to check if the thrust bearing above the spindle is supporting the car. A lot of spindles got worn an that lets the spindle drag. Check the clearance between the bottom of the axle and the top of the bottom spindle lug with a feeler gauge. Last edited by Andy; 08-12-2019 at 10:57 AM. |
08-12-2019, 04:58 PM | #19 |
Will this require a short-arm inspection?
08-12-2019, 08:47 PM | #20 |
I have a ‘32 frame under my AV8. I also have a lot of different pitman arms. Give me a few days to sort them out. Maybe there is a solution in Henry’s parts pile. You can add a ball stud to the later style pitman arms.
