06-07-2015, 05:54 PM | #1 |
Question: How to re-orient big truck 2-speed axle shift lever in axle
Ford Barners,
My ’47 COE has the 2-speed Ford/Eaton rear axle. From ’45-47, the axle was shifted by vacuum. Due to the fact that vacuum diaphragms and switch valves are not obtainable new and therefore unlikely to be reliable, I intend to retrofit my ’47 truck with a ’42 COE mechanical (lever) shift assembly. In order to install it, I need to re-orient the shift fork lever located in the rear axle. In the 45-47 vacuum shifted trucks, the end of L-shaped lever points away from truck centerline (towards wheels) and the earlier 40-44 trucks require the shift lever to point towards the centerline (towards driveshaft). I’ve included diagrams showing the 40-44 and 45-47 orientations. The cutaway picture indicates that the shift lever in the axle is splined (see no. 23). The Ford green parts book indicates the lever is the same regardless of year. I should therefore be able to re-orient it. My question is: Can I re-orient this lever without disassembling the entire rear axle carrier? I’m looking for anyone who might have experience rebuilding one of these axles. Thanks much. Dan |
06-07-2015, 07:47 PM | #2 |
Re: Question: How to re-orient big truck 2-speed axle shift lever in axle
Use an idler lever pivoted in the center in the rods going back, push becomes pull, and vice/versa. No change needed at the rear.
06-07-2015, 09:38 PM | #3 |
Dan |
