10-11-2020, 08:46 AM | #21 |
Re: Juice brakes
Thanks Bruce , I had seen that article , pictures are worth a 1000 words
10-11-2020, 10:31 PM | #22 |
Re: Juice brakes
I probably would have gone that way, but when I saw all the cutting and grinding required, I opted to go the Randy Gross route with "stock" cast drums. So far I haven't been sorry for that decision, plus it was about half the cost of the MT conversion.
10-12-2020, 12:03 AM | #23 | |
Re: Juice brakes
Have you figured out how you're going to actuate the master? Stock Model A pedal is set up to pull as opposed to push, which can make things interesting. Good luck and enjoy your A! |
10-12-2020, 01:58 AM | #24 | |
Re: Juice brakes
http://www.bolingbrothers.com/model-...ke-conversion/ |
10-12-2020, 06:56 AM | #25 | |
Re: Juice brakes
10-12-2020, 07:31 AM | #26 |
Re: Juice brakes
10-12-2020, 02:32 PM | #27 |
Re: Juice brakes
My '40 master cylinder is on the passenger side of the car. Bolted on the front of the cross member and actuated by the mechanical brake crossover shaft.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
10-12-2020, 04:31 PM | #28 | |
Re: Juice brakes
I have my master mounted on the crossmember and fabricated the linkage to pull on the master cylinder. This design allowed me to control the amount the pedal traveled vs. bore stroke in the master by adjusting the pivot points and thereby changing the pedal ratio similar to a hanging pedal setup. [IMG]1930 Ford Master cylinder and brake lines-91 by PotvinV8, on Flickr[/IMG] |
10-12-2020, 06:46 PM | #29 |
Re: Juice brakes
Thank you Potvin
10-12-2020, 07:03 PM | #30 | |
Re: Juice brakes
Opinion from a less experienced 57 year old younger perhaps more idealistic phart r
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
10-22-2020, 12:53 AM | #31 | ||
Re: Juice brakes
Show me a 60-0 brake test and then show me the third, forth, and fifth result...LOL |
