Old 05-20-2015, 07:58 PM   #1
Leon
Default Tom & Purdy - Brake adjustment
I use your method for adjusting the front brakes ( it is quite easy to remove the pin from the brake rod clevice) but I can't remove the pin from the rear clevice rods. I am on my back like a contortionist and I just can't remove the pin. Is there a simpler way - is a lift necessary?
I must be doing something wrong and your advice would be appreciated.
Leon is offline   Reply With Quote
Old 05-20-2015, 08:02 PM   #2
Mitch//pa
Default Re: Tom & Purdy - Brake adjustment
what about removing it off the service brake shaft? thats where the adjustment is also
for stubborn pins i use a side cutters / dykes to get under the pin head and pry out
Old 05-20-2015, 08:39 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, what Mitch said. I always remove the pins from the front of all 4 service brake rods.
