Old 07-12-2019, 09:28 PM   #1
bdtutton
Default A little wood rot around screw holes
The wood is slightly rotted around some of the screw holes in my car. The previous owner solved the problem by putting in slightly larger screws and it seems to have worked for a while. The problem is they seem to have been over tightened and partially stripped. Several of the screws are losing their grip and I guess I could replace them with yet another size bigger, but in this modern day I was wondering if there was some sort of wood putty I could put into the holes and then re-drill them back to their original size and use the original size screw.
bdtutton is offline   Reply With Quote
Old 07-12-2019, 09:36 PM   #2
Gary WA
Gary WA's Avatar
Default Re: A little wood rot around screw holes
Good wood glue with hardwood plugs like match stick size or a good 2 part epoxy.
www.whidbeymodelaclub.com
Old 07-12-2019, 10:23 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Find something like "Git Rot" and soak the area to stop the rot. If possible drill out the hole after treatment and insert (glue) in a dowel. Once everything dries drill a pilot hole and insert the proper size screw.
Mike V. Florida is online now   Reply With Quote
Old 07-13-2019, 12:25 AM   #4
Ray in La Mesa
If you have access, drill out screw hole to a dowel size, insert & glue dowel and redrill hole to proper size screw.
Ray in La Mesa is offline   Reply With Quote
Old 07-13-2019, 04:55 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
This is what we do. Hardwood dowels are available at most local hardware or lumber stores.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-14-2019, 09:46 AM   #6
taffrail
taffrail's Avatar
Get out your pocket knife and whittle up some pre cut Maple or other hard wood sticks, tap in with a good wood glue, cut off and drill with a Vix-Bit or other centering drill.
Larger or longer screws might not have the correct head.
taffrail is offline   Reply With Quote
Old 07-14-2019, 12:04 PM   #7
Curtis in MA
Did you solve the cause of the rot first, or will the new plug rot too?
Curtis in MA is offline   Reply With Quote
Old 07-14-2019, 05:33 PM   #8
DHZIEMAN
I use pieces of split oak firewood from my woodpile. There are always slivers of oak loose on the logs to be pulled off in various sizes or trimmed with a pocket knife for gluing into oversize holes And good wood glue will do the job! Titebond is available her locally at Lowes.
DHZIEMAN is offline   Reply With Quote
Old 07-15-2019, 07:49 AM   #9
77Birdman
I would try this first. No need in drilling out oversize. You more than likely can find a scrap of wood laying around cut the corner off with a knife and use that as a plug. Being this will be subject to the weather (maybe) I would use tightbond III glue, which is good for outdoor use. By your description it doesn't sound like the area is rotted, if it is, then you need to go to plan B.
77Birdman is offline   Reply With Quote
Old 07-15-2019, 05:50 PM   #10
Synchro909
Synchro909's Avatar
If you are gluing a plug into the hole DON"T use PVA glue. It will cause the screws to rust in short time.
I believe it is to do with the acetic cure of PVA but stand to be corrected on that.
Nobody told me rigor could start while I'm still alive.
Old 07-15-2019, 09:33 PM   #11
Ed Wendell
Ed Wendell's Avatar
If you decide to drill and plug with a dowl, check out Rockler Woodworkers Hardware for SCREW EXTRACTORS. Also handy to have around if you break a screw.
Ed Wendell is offline   Reply With Quote
Thread Tools
Display Modes
