Old 07-05-2019, 06:04 PM   #1
History
Default Need help on literature
Iíve read it on here more than once and I know the authors name is les Andrews. Which books of his should I acquire before I start doing maintenance? Iím not doing a restore. I plan on repairing what needs to be and maintaining/replacing consumable parts.
I pulled the (((front))) hub today as I could feel the bearing was loose. I also took the brake linings off and cleaned things up some. The parts had been greased (the rollers and the brake adjusters). I greased those parts and replaced them and now Iím questioning myself if Iíve done the correct thing. I know the adjusters get greased in the housing but Iím not sure about the wedge and rollers???? They had been as there was dried sticky molasses like grease on them.
I need the literature to be confident in What Iím doing.
Thanks
History is offline   Reply With Quote
Old 07-05-2019, 06:25 PM   #2
Steve Plucker
Steve Plucker's Avatar
Default Re: Need help on literature
Weather you are restoring or maintaining...Here is Les's book: Model A Ford Mechanics Handbook...A Complete Guide for Service and Maintenance.
Pluck
www.plucks329s.org
Walla Walla (WA) Sweet A's since 1993
MARC/MAFCA member since 1978
Ford Model AA Truck Club since 1998
(LIONEL/MTH Toy Train Collector, Orange Crush Soda Collector, Steel Beer Can Collector, Old Gas Pump Collector)
Steve Plucker is online now   Reply With Quote
Old 07-05-2019, 10:49 PM   #3
daveymc29
daveymc29's Avatar
As Steve said, the Mechanics Handbook, it is the red covered book, will get you through the maintenance of most items. If you machine has accessories I's go with the rest of the series. All three books have things that at some point you probably will find yourself wondering about. But, for starters at least the red book. That is troubleshooting, fix it and maintenance. The other two are good to know but not critical to keeping your car in good tune and reliable.
daveymc29 is offline   Reply With Quote
Old 07-06-2019, 12:14 AM   #4
History
Thanks guys,, I'll get the red book to start with.
Old 07-06-2019, 11:10 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I don’t think you want to grease the rollers, for the very reason you stated. Grease attracts grit, and also as you noticed, can congeal and cause sticking.
Old 07-08-2019, 09:15 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
I have all three, as a matter of fact I have 2 "red" books, one dirty for the garage and one for the house. I don't think I've opened the other two (blue, green) since I bought them.
Old 07-09-2019, 07:08 AM   #7
Werner
Werner's Avatar
I am also very interested in good literature.
Is the red mechanics handbook book I. by comparable to the restorers book (bottom left) by Victor Page? Or is the red book an increase / completion / better?
I can not test that myself because I have to order the book in USA.
Many thanks for the hints!
Beste Gruesse aus Deutschland,
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 07-09-2019, 09:30 AM   #8
daveymc29
daveymc29's Avatar
The red book is full of pictures and drawings to help with visualizing what the written text is telling you. I find that very valuable. Very easy to follow most instructions with good explanations of what to do, in order. Your results may vary, just my opinion.
Old 07-11-2019, 08:43 AM   #9
Werner
Werner's Avatar
Hello "book worms", because of the high transport costs, I may perhaps consider all three books to buy in USA.
Can anyone please give some hints what is described in Book 2 and Book 3?
The original edition has no spiral binding but is glued to the back, do I think right?
Werner
Citroen 11 CV, 1947
Old 07-11-2019, 08:09 PM   #10
History
The first book or (Vol1) is titled " complete guide for service and maintenance. The second book (Vol2) is titled "complete guide for installation and assembly for body wood, hydraulic brake systems and all aftermarket products. The third book (Vol3)is titled " complete guide for trouble analysis and testing. The first book is red, the second is green and the third is blue.
I do not know if the original or 1st edition is bound or not. My books all have something similar to a spiral binding but it isn't as you can add or change pages if you wish.
Old 07-12-2019, 03:54 AM   #11
Werner
Werner's Avatar
Thank you, History. Great help.
I buyed now only the red one in USA. ($ 70 incl. freight!)
Werner
Citroen 11 CV, 1947
Old 07-23-2019, 03:34 PM   #12
Werner
Werner's Avatar
Today I received the red book from Andrews. It is a good book that is highly recommended for every A driver. "Must have every A-man".
Much is already known from the old Ford publications. But here are some helpful hints that are adapted to the current situation.
I really like the clear layout. Sorted by A-B-C, each chapter is completely handled and you do not have to jump to many pages to find a single function completely.
Thank you for your helpful advice!
(I know, you too, my language is bad. Thanks therefore once more!)
Werner
Citroen 11 CV, 1947
Old 07-23-2019, 05:23 PM   #13
Synchro909
Synchro909's Avatar
Werner, Don't blindly follow the instructions in that book. It contains many errors but is still a valuable reference.
Somewhere, I saw someone trying to compile a list of those errors but didn't see the outcome. Maybe someone else knows.
The journey from birth to death is best undertaken slowly.
Synchro909 is online now   Reply With Quote
Old 07-23-2019, 05:44 PM   #14
Werner
Werner's Avatar
Oh, that makes me sober. Thank you very much for this note. Of course, I'm very interested in bug-examples.
Thanks all in advance!
Werner
Citroen 11 CV, 1947
Old 07-24-2019, 10:21 AM   #15
Jim Brierley
Gutentag Werner, the red book is great but use caution with it. Les and I disagree on a few things, like rear end assembly method, but it is still very valuable. Your english is far better than my Deutch, you are doing good!
Jim Brierley is offline   Reply With Quote
Thread Tools
Display Modes
