Old 05-18-2019, 10:35 AM   #1
tommyleea
Default Coolant
Any thoughts on Evans waterless coolant? I was thinking of using it in my 53 Ranchwagon. Fresh rebuilt flathead, and nothing in the cooling system yet. I figured this would be a good time to use it. Seems like it would be perfect for a seldom driven vehicle.
tommyleea is offline   Reply With Quote
Old 05-18-2019, 11:49 AM   #2
3739ford
3739ford's Avatar
Default Re: Coolant
https://www.jalopyjournal.com/forum/...roduct.583554/
3739ford is offline   Reply With Quote
Old 05-18-2019, 01:39 PM   #3
TJ
TJ's Avatar
Default Re: Coolant
All Evans does is lighten your wallet. A nice clean cooling system and regular 50-50 coolant and water will work just fine.
Old 05-18-2019, 02:35 PM   #4
tommyleea
Default Re: Coolant
I guess I was thinking more on the rust prevention side. After further review I will go with antifreeze.
Old 05-18-2019, 06:13 PM   #5
Flathead Fever
Flathead Fever's Avatar
Default Re: Coolant
Save your money. Just use a 50/50 mixture of Prestone and change it every two year's to prevent electrolysis. A flathead is just an engine like any other engine, it does not need any kind of magic coolant.
Flathead Fever is offline   Reply With Quote
Old 05-27-2019, 10:01 AM   #6
philipswanson
Default Re: Coolant
A coupla bottles of water wetter will help. It reduces the bubbles between the inner surfaces and the coolant to promote better cooling. Take it easy on the anti freeze because it will raise your boiling temps but increase your coolant temps.
philipswanson is offline   Reply With Quote
Old 05-27-2019, 08:59 PM   #7
aussie merc
aussie merc's Avatar
Default Re: Coolant
any good quality premix coolant works fine [QUALITY]is the catchword
aussie merc is offline   Reply With Quote
Old 05-31-2019, 02:58 PM   #8
philipswanson
Default Re: Coolant
Premix is a waste of money. Get the concentrated stuff and add your own distilled water. Now you have twice as much coolant for pennies more.
Old 06-01-2019, 02:24 PM   #9
supereal
supereal's Avatar
Default Re: Coolant
I use propylene glycol, sold under the brand name "Sierra". It works fine, and will not pollute or poison pets if any leaks.
supereal is offline   Reply With Quote
Old 06-01-2019, 09:10 PM   #10
aussie merc
Default Re: Coolant
yes premix costs more but the mix ratio is important if the coolant is to work correctly ie freeze point , boil point and corrosion resistance if your confident to mix your own that's a bonus, premix is peace of mind
Old 06-02-2019, 12:21 AM   #11
50fordcoupeman
50fordcoupeman's Avatar
Default Re: Coolant
Agree with you. Mix of 50/50 of concentrate with water. Been doing it for years in the Pacific Northwest............
50fordcoupeman is offline   Reply With Quote
Old 06-02-2019, 07:00 AM   #12
flatford8
flatford8's Avatar
Default Re: Coolant
I mix mine but it still should be tested for its freeze point. Im careful to mix it correctly and had a batch that wasn’t low enough. I think it was 50/50 in a “concentrate” container....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Thread Tools
Display Modes
