07-12-2019, 01:53 PM | #1 |
Heater temperature control valve 302 engine
My avatar has a 1971 302 engine. The car has the original heater. The heater control valve doesn't shut off completely. The NAPA parts man THINKS the current valve is installed on the wrong heater hose. My question is does the valve go in the the line coming from the water pump or does it go on the line going into the intake manifold?
Thank you!!! |
07-12-2019, 03:01 PM | #2 | |
Re: Heater temperature control valve 302 engine
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
07-12-2019, 03:19 PM | #3 | |
Thank you Kultulz!! |
07-12-2019, 03:33 PM | #4 |
Correct. If it is @ the WP return, the HTR CORE will not see constant hot coolant but just enough to make it uncomfortable in the summer.
07-12-2019, 03:49 PM | #5 |
07-13-2019, 03:05 AM | #6 |
