Old 07-05-2019, 01:26 PM   #1
rer_239
rer_239's Avatar
Default Timing
The rotor inside the distributor has a wide contact. Should the #1 terminal be centered in the rotor contact?
After using the timing pin to find tdc. If someone do I loosen the distributor body to center it?.
Thanks
Dick
rer_239 is offline   Reply With Quote
Old 07-05-2019, 01:46 PM   #2
Will N
Will N's Avatar
Default Re: Timing
No. You loosen the distributor cam to change the timing. At full retard, the trailing edge of the rotor contact should line up with the #1 terminal.
Will N is offline   Reply With Quote
Old 07-05-2019, 01:47 PM   #3
zzlegend
zzlegend's Avatar
Default Re: Timing
See the last picture of this thread.
http://www.fordgarage.com/pages/ignitorB.htm
zzlegend is offline   Reply With Quote
Old 07-05-2019, 05:02 PM   #4
1931 flamingo
1931 flamingo's Avatar
Default Re: Timing
Do you have the "Red" mechanics book??
Paul in CT
Old 07-06-2019, 03:55 AM   #5
rer_239
rer_239's Avatar
Default Re: Timing
Yes I have it
Thanks
Dick
Old 07-06-2019, 06:53 AM   #6
Penthode
Penthode's Avatar
Default Re: Timing
Of course the rotor positioning dictates the firing order. The points opening dictates the absolute timing.
Penthode is offline   Reply With Quote
Old 07-06-2019, 01:03 PM   #7
30 Closed Cab PU
Default Re: Timing
Gap the points before timing via the cam.
Old 07-06-2019, 01:34 PM   #8
Nick in Fayetteville
Default Re: Timing
Good idea to gap the rotor and the distributor body contacts too.
Nick in Fayetteville is offline   Reply With Quote
Old 07-06-2019, 03:43 PM   #9
30 Mike
Default Re: Timing
Also keep in mind the rotor turns counterclockwise
30 Mike is offline   Reply With Quote
Old 07-06-2019, 09:47 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Timing
https://web.archive.org/web/20181005...hop/timing.htm
