Old 06-17-2019, 12:43 PM   #1
Rayfry
Default Transmission Leaking
I have a 1949 Ford Custom with a leaking transmission. It is coming from the front of the trans. Its a manual 3 spd with o.d. I take it its the front seal but not sure. Do any of the transmission additives that they sell on the market actually work? They claim they will stop leaks and seal the transmission. I am trying to avoid pulling the trans.
Rayfry is offline   Reply With Quote
Old 06-17-2019, 12:57 PM   #2
JSeery
JSeery's Avatar
Default Re: Transmission Leaking
Additives normally consist of something that softens the seals. Not a very good solution. Sorry for the bad news, but think the only solution involves pulling the trans.
Old 06-17-2019, 01:00 PM   #3
tubman
tubman's Avatar
Have you checked to see if the transmission has been over-filled? Probably not, but I'd check that before I pulled it out.
Old 06-17-2019, 05:19 PM   #4
Mac VP
Mac VP's Avatar
The 49-56 Ford passenger three speed transmissions (including the overdrive type) were not made with a front oil seal. If the oil level is correct and the car is parked on level ground, it should not leak out the front bearing retainer when parked. If, for some reason, the front oil baffle is missing (located behind the front ball bearing) it could be throwing some oil out the front retainer when driving the car.
If the front bearing retainer is loose, you would have oil leaking out past the gasket.
Sealed front bearings can be found to replace the original open style bearing. I’d recommend pulling the rear plastic shield from the sealed bearing to allow oil to get into the balls. The front plastic shield would keep it inside the bearing.
VANPELT SALES LLC
Cincinnati, Ohio
800-299-7496 (in USA)
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 06-17-2019, 06:53 PM   #5
Talkwrench
Talkwrench's Avatar
is it trans fluid....?
Old 06-17-2019, 06:55 PM   #6
oldskool
oldskool's Avatar
I would try thicker gear oil like 140 drain the old oil and refill with the thicker gear oil
oldskool is offline   Reply With Quote
Old 06-18-2019, 11:42 AM   #7
Rayfry
The trans leaks when it is parked. You can actually watch it drip after I park it.
Old 06-18-2019, 06:31 PM   #8
Tinker
Tinker's Avatar
I thought these old fords needed to mark their spot. I wouldn't worry. put some cardboard under it. It's normal, or at the very least not a big deal if there is a spot under it. A quart... worry.
Old 06-18-2019, 06:40 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
check to see if vent is clogged with dirt or spyder/mud wasp,etc
Old 06-18-2019, 08:21 PM   #10
Mtn Wudy
Mtn Wudy's Avatar
Don’t the O.D. Trans’ take a special gear oil ....???
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
