Old 04-24-2018, 06:49 PM   #1
bobgc
bobgc's Avatar
Default 5 speed trans on a flethead
some time ago I saw a 36 panel truck which had a five speed od trans in it and still had the closed drive shaft, anyone know how you do that? I am considering doing the same. I know you can do that with a s-10 trans but you have convert to open drive and I would rather not do that if I don't have to.
bobgc is offline   Reply With Quote
Old 04-24-2018, 07:10 PM   #2
JSeery
JSeery's Avatar
Default Re: 5 speed trans on a flethead
You can do it with a T5. There was a detailed thread on the setup, an adapter to the closed driveshaft is used in place of the normal tail cone piece.
Old 04-24-2018, 07:21 PM   #3
bobgc
bobgc's Avatar
I am not sure I know what a T5 is I have a 5 spd. from a 94 F350 will that work ?
Old 04-24-2018, 07:25 PM   #4
cas3
thats an awful big transmission. try this...google- t5 fordbarn you will be reading into next week
Old 04-24-2018, 07:27 PM   #5
JSeery
JSeery's Avatar
T5s were used in S10 pickups, Camaros, Mustangs, and other cars/trucks. Anything can be made to work with anything if you spend enough time and money! The T5 is a proven approach with lots of supporting data.
https://www.fordbarn.com/forum/showt...t=transmission
Old 04-24-2018, 07:31 PM   #6
cas3
and, as a bonus that f350 trans is worth a lot if its known to be good. that would finance a big chunk of a t5 project
Old 04-24-2018, 08:01 PM   #7
bobgc
bobgc's Avatar
Ok thanks for your help i'll go on the site and read all about it thanks again
