07-17-2018, 12:35 PM | #1 |
40 convertible
Building a 40 convertible Cant identify this brace please help with any info.
See attached photo. |
07-17-2018, 02:29 PM | #2 | |
Re: 40 convertible
It's the rear seat rizer..although it isn't an original one. The original one is cut out in the center for the hump, and has two metal knobs sticking out that accept the seat cushion.
"Get your facts first..then you can distort them as you please" |
07-17-2018, 02:32 PM | #3 |
Re: 40 convertible
Could it be the seat riser for the front bottom of the back seat?
The seat bottom rests on this somehow? Looks homemade as the one's I've seen fit snugly against the tunnel and floor. |
07-17-2018, 03:29 PM | #4 |
Re: 40 convertible
Here's a photo from the trunk vantage point.
07-18-2018, 07:31 AM | #5 |
Re: 40 convertible
Thanks for the info guys. Guess I can make one from a piece of pine.
07-18-2018, 07:52 AM | #6 |
Re: 40 convertible
07-18-2018, 09:32 AM | #7 |
Re: 40 convertible
Convertible cars needed the extra cross bracing to help secure the B-pillars. They can get shaky with poor bracing. I'd use ash or white oak if it was me. It looks like the car has had some metal work done in that area. Most converts like to rust in there if not stored well so that isn't unusual.
07-19-2018, 04:30 AM | #8 |
Re: 40 convertible
07-20-2018, 02:50 PM | #9 |
Re: 40 convertible
What are the dimensions of the board 2 X?
07-20-2018, 07:51 PM | #10 |
Re: 40 convertible
If you'd like to make your life real easy, call Roy Nacewicz. he has all the wood pieces available for the '40 convertible. They are BEAUTIFUL reproductions. He had used a great set of authentic boards I'd sent him for patterns. His price for the entire set is not much more than you'd pay for quality lumber.
07-21-2018, 01:46 PM | #11 |
Re: 40 convertible
Thanks for the info.
How do I contact Roy Nacewicz? |
07-21-2018, 05:26 PM | #12 |
Re: 40 convertible
734-654-9450
07-22-2018, 07:41 AM | #13 |
Re: 40 convertible
Thank you so much.
07-22-2018, 08:23 PM | #14 |
Re: 40 convertible
07-27-2018, 06:19 AM | #15 |
Re: 40 convertible
Hi guys
Can you please provide the size of the cross board I need? 2x. Roy Nacewicz does not answer or return phone calls or Faxes. Please help Thanks. |
07-27-2018, 07:21 AM | #16 | |
Re: 40 convertible
I hope he is okay....
