Old 01-12-2020, 11:11 AM   #1
30-9
Default 39 rear drain plug
Hi Gents
Trying to drain and replace rear gear oil. The drain plug is square female.
What tool do you guys use? I tried my 1/2 it’s too big and 1/4 too small.
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 01-12-2020, 11:14 AM   #2
JSeery
JSeery's Avatar
Default Re: 39 rear drain plug
Is it 3/8, like the end of an extension? Can't remember if the 3/8 works directly or if you have to grind them down a bit.
Old 01-12-2020, 11:17 AM   #3
Mart
Mart's Avatar
I took a 1/2" allen bolt and ground/filed the end square with a slight taper. I haven't used that for ages though, 9 times out of 10 a 3/8 ratchet fits well enough to undo the plugs.
Mart.
Old 01-12-2020, 11:37 AM   #4
Kube
Kube's Avatar
3/8" ratchet works fine.
Old 01-12-2020, 12:11 PM   #5
30-9
The 3/8 ratchet is too small. My old arms/muscles need the 1/2 breaker bar. I also think it’s closer to 7/16 than 3/8. I’ll borrow a 1/2 - 7/16 pipe plug remover socket.
Thanks - 30-9
1939, 1940
Old 01-12-2020, 12:36 PM   #6
Kube
Kube's Avatar
000
Old 01-12-2020, 12:48 PM   #7
30-9
Kube when your 85 try and let me know how you make out.
Thanks - 30-9
1939, 1940
Old 01-12-2020, 01:01 PM   #8
VeryTangled
VeryTangled's Avatar
Hi Everyone, on my '35 and '36 the female square in the rear drain and fill plugs are not an exact fit for a 3/8 extension or ratchet. But that's the tool I use. I just try to be as gentle as possible.
Maybe a long handle 3/8 ratchet or a 1/2 to 3/8 adapter on your 1/2 inch ratchet or breaker bar? I can't believe I'm saying this but maybe a shot of slick-em-up would make it turn easier?
I might suggest you make sure the fill plug is free before you try to get the drain plug out.
-Jeff H
Old 01-12-2020, 01:08 PM   #9
ford38v8
ford38v8's Avatar
Originally Posted by Kube View Post
Okay. I've only done a zillion of them. My 3/8" ratchet must not be 3/8" after all.
As we get older, we also tend to misunderstand each other more often, but of course I never had that problem myself.
Alan
Old 01-12-2020, 01:23 PM   #10
marko39
Plug may be worn on inside making it look bigger. When you do get it out you could replace it with a male plug which is easier to work with.
marko39 is offline   Reply With Quote
Old 01-12-2020, 01:32 PM   #11
Brian
Brian's Avatar
I use a home made tool for that purpose; I used a piece of 1/2" keysteel [1/2x1/2 square], ground the end down with a slight taper to approx 7/16", so it fitted the plug nicely, then heated and bent the steel 90* so it resembles an allen wrench.
Old 01-12-2020, 01:32 PM   #12
JSeery
JSeery's Avatar
Lots of ways to work with 3/8 such as cheater bars over the handle, adapter for a 1/2 drive, etc.
Old 01-12-2020, 01:33 PM   #13
30-9
Good advise, thanks. I still need the length / leverage from the breaker bar. At 85, laying on my back, I need all the assistance I can get from the tool.
Thanks - 30-9
1939, 1940
Old 01-12-2020, 01:50 PM   #14
deuce_roadster
deuce_roadster's Avatar
I have a tool that each end has 4 different size square male protrusions on it and I can always find one that will work, even on plugs that have been messed up and enlarged.
Old 01-12-2020, 02:26 PM   #15
Terry,OH
Terry,OH's Avatar
Ford put the tool on the end of the adjustable wrench in the tool kit.
Old 01-12-2020, 02:54 PM   #16
Kube
Kube's Avatar
If I make it to 85, I'm willing to bet I'll still know the difference between 3/8" and 7/16".
Old 01-12-2020, 03:05 PM   #17
cadillac512
cadillac512's Avatar
LOL, what he's saying,guys, is that he needs the length of the 3/8" tool handle to be as long as the 1/2" so he has enough arm strength to loosen the plug.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 01-12-2020, 03:07 PM   #18
V8COOPMAN
V8COOPMAN's Avatar
I wanna see that 7/16" ratchet! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-12-2020, 03:20 PM   #19
30-9
Terry
Correct! And the 7/16 is the male socket. And I thought I had senior moments.
At times this site just likes to bust chops!
Thanks - 30-9
1939, 1940
Old 01-12-2020, 04:21 PM   #20
Kube
Kube's Avatar
000
