12-08-2019, 05:02 PM | #1 |
Radiator neck pliers?
Trying to get the outlets on my 35 radiator round again. I did a search online and can’t come up with anything because all the new radiators are plastic and aluminum, and the tools for them are completely different.
Does anyone know where I can get the old style pliers for reshaping the outlets on radiators? Specifically looking for one that will do one and a half inches. |
12-08-2019, 05:11 PM | #2 |
Re: Radiator neck pliers?
Would a tail pipe expander work? It would be the insertion depth that I would wonder about.
https://www.harborfreight.com/Medium...der-63703.html Glenn |
12-08-2019, 05:15 PM | #3 |
These aren't "old style" but they will probably do the job >
12-08-2019, 05:20 PM | #4 |
The ones I remember when I used to work at a radiator shop when I was a teenager have a 90° Bend at the end and it goes in the radiator outlet to shape it properly. There were serrations on the 90 ‘ end but other than that look like a regular pair of pliers.
12-08-2019, 05:29 PM | #5 |
Like these? >
https://www.ebay.com/itm/VINTAGE-UTI...oAAOSwKS9d5~fL or these? > https://www.ebay.com/itm/2x-Vintage-....c100752.m1982
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 12-08-2019 at 05:38 PM. |
12-09-2019, 02:21 AM | #6 |
12-09-2019, 04:13 AM | #7 |
Would this tool work?
https://www.ebay.com/itm/Tail-Exhaus...e/270637622265 |
12-09-2019, 04:33 AM | #8 |
I use progressively larger wrench sockets.
12-09-2019, 05:12 AM | #9 |
Ralph, I have a set of tail-pipe expanders like duce lover showed a link to. they come in several sizes. I have used them on radiators before, and they work fairly well, but you have to watch that you don't "dis-figure the flare " at the mouth of the outlet.
12-09-2019, 01:52 PM | #10 |
Yeah I guess I’ll have to use a muffler pipe expander, I just remembered a tool that was a whole lot different when I used to work at a radiator shop as a teenager.
12-09-2019, 02:28 PM | #11 |
Like these?
12-10-2019, 12:58 AM | #12 |
12-09-2019, 02:37 PM | #13 |
Pete I believe those are battery terminal pliers.
12-09-2019, 02:44 PM | #14 |
Yes, they are...But they kinda match Ralph's description...Just have to find one that opens wider.
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 12-09-2019 at 03:35 PM. |
12-09-2019, 05:09 PM | #15 |
David's idea to use progressively larger sockets does work. I recently did this on a squashed STEEL breather pipe for my Nash and it worked a treat, so with a brass radiator pipe it should work even easier.
I used the socket the wrong way around, fitting a 12 inch extension from the nut/bolt end, to make it easier to hold the socket and also putting the square drive side into the pipe first. Doing it this way around makes it easier as it then has a sort of natural taper going into the pipe. Once you have expanded the pipe as close to the original size, you can then use the socket inside the pipe as a sort of "DOLLY" while you use a small hammer to plenish out any dents IF necessary. |
12-10-2019, 01:47 AM | #16 |
12-10-2019, 11:37 AM | #17 |
Is this what you want?? http://www.johnsonmfg.com/2015/410.HTM
12-10-2019, 04:19 PM | #18 | |
12-10-2019, 01:41 PM | #19 |
Found this slick home built tool to do exactly what the OP needs. https://youtu.be/v5WS7UhR25I
12-11-2019, 03:26 PM | #20 |
The Youtube link that Scott posted in message #18 is great. I like the use of the muffler clamp backer. I made this tool to make a "bump" for a trimmed SS radiator pipes using a very old pair of vice grips.
I marked a line around the pipe/tube OD and then made a few passes all the way around, The trick is to make the "roll" a little at a time. Glenn Last edited by glennpm; 12-12-2019 at 11:18 AM. |
