Old 02-23-2020, 12:55 PM   #1
Fordestes
Default Piston /ring question
I have a set of .005 o.s. 09A 3ring aluminum pistons , will standard rings be sufficient to use ? As I remember from my childhood, we used this combination ,however what we did does not necessarily mean it was correct. I have thought about machining pistons to standard and using standard rings in a fresh bore, finding .005 rings may be impossible. What is the accepted practice ? I was always told standard rings were good up to .010 ?
fordestes
Fordestes is offline   Reply With Quote
Old 02-23-2020, 01:10 PM   #2
frnkeore
frnkeore's Avatar
Default Re: Piston /ring question
Your memory is right, the difference will be the increased end gap of almost .016.
If your putting them in a used bore (don't know where you'd find a new std bore), you will have a little taper and increased gap, to begin with so, it shouldn't be a issue.
Have it honed by a good machine shop, to minimum fit. As you say, .005 rings would be HARD to come by.
Maybe someone here can tell you where they could be found.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 02-23-2020, 01:20 PM   #3
flatheadmurre
flatheadmurre's Avatar
The losses due to that extra ring gap will be very little...on a stock engine i wouldn´t worry.
File fitting a set of .010 might be what looks like the correct way...but ouch what an amount of work to gain a %...
And machining pistons takes a dedicated grinder or a cnc-lathe with C-axis...not sure it will cost less then a set of pistons nowdays...
Old 02-23-2020, 02:21 PM   #4
Fordestes
I am planning to bore some 221 engines to 3-3/16., and use up some N.O.S parts I have and install the engines in my trucks .
Many thanks , fordestes
Old 02-23-2020, 04:47 PM   #5
frnkeore
frnkeore's Avatar
Be aware that the maximum thickness of the cylinder wall will be .103 (@.005 over), IF there is no core shift and no cylinder wall erosion.
I have two, original Ford drawings for 21 stud blocks. One lists the outside, cylinder, core diameter as 3.38, the other 3.40.
Personally, I don't think they should be bored more than .090 over. My 37 block, is .040 now (with deep pits in #3) and I have a set of .080 over, pistons and rings for it. I found both on Ebay. I took awhile though.
Frank
'35 Ford Model 51
'48 Ford F3
Old 02-23-2020, 05:02 PM   #6
frnkeore
frnkeore's Avatar
These are clips from the drawing. The 3.40, is based on the radius of 1.7 in the one drawing but, I believe the target for the outside of the cylinder is a diameter of 3.38, leaving .094 wall thickness, again, IF there is no core shift and no erosion.
Frank
'35 Ford Model 51
'48 Ford F3
Old 02-23-2020, 07:28 PM   #7
Fordestes
These 221 engines are 41 models and have removable sleeves , with the sleeves removed there shouldn't be a whole lot more to be removed , I'm just guessing about .040 more to make a standard 239 , ford offered pistons as a replacements with the sleeves removed , they were in the .080 range if I remember right, if there are problems I will either put in a thin wall 3-3/16 sleeve or scrap the block and start over. I have plenty of the 221 blocks that do not seem to be in high demand these days, I just want to try and put them to work instead of walking around them for the next decade . Thanks everyone for your input .
Old 02-24-2020, 02:55 AM   #8
frnkeore
frnkeore's Avatar
OK, so it's not a 21 stud engine so, I think it should be fine with that 3.193 bore.
Frank
'35 Ford Model 51
'48 Ford F3
Old 02-24-2020, 10:31 AM   #9
Fordestes
Sorry I didn't clarify that to begin with ,but I gained a wealth of knowledge just the same, I like the drawing ,I'll copy and add it to my files .Thanks
