09-01-2017, 07:45 PM | #1 |
Undersized Kingpins .... NEW
Has anyone else run into suppliers selling undersized kingpins?
I am working on a '36 Sedan that is getting '37 spindles and Lincoln Brakes. The Drake Kit that was brought to me "seemed" quality made... I put the bushings in and reamed them to the correct factory size the same as I have always done. I dropped the new kingpin in to test the fit and it was loose!! I thought I somehow cut the size too large.... Nope! The NEW kingpins measured in the neighborhood of .805 to .806... about .0050+ too small So I called Bob Drake and was told all the others are the size that I measured and they've been selling them for years with no complaints... why didn't I measure first and make it match the pin....trying to explain that having a small kingpin in the axle wedged off to one side didn't seem like a viable solution to me... I finally got him to agree they were wrong but he didn't seem to care!.... I gave up and called Dennis Carpenter to have theirs measured... A much nicer employee at DC then at Drake told me theirs are right around .8 ".8 what".... ".8 is what I'm getting"..... then told me in metric its 2 and a hair, or something like that..... no micrometer in sight... but I learned the manufacturer and that they're from the good ol' USA! (that'll help them grow!).... So I was pretty frustrated and talked to a friend who recommended the early ford store in California has good ones.... Does anyone else have any recommendations as to where to go for the CORRECT size kingpins? To me this seems like a part that should be correct...am I wrong? thank you for any insight anyone can offer..... I don't mean this as a major negative overall against the companies that I talked to... I just expected a little bit better from them (.0050) Edited... my mistake typing .050 instead of .005
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads Last edited by SUHRsc; 09-02-2017 at 10:51 AM. |
09-01-2017, 08:52 PM | #2 |
Re: Undersized Kingpins .... NEW
So what king pins are you going to use, '37? I have a pair that I believe to be '37-'41 king pins that I just measured at .812".
09-01-2017, 08:53 PM | #3 |
What I think you have are Lincoln spindles that use a .858 king pin IIRC. They could be used on a Ford axle if the k/p hole in the axle was reamed or bored for the larger diameter, but also you would need to correct the camber because the '37-'41 Ford round back spindle has a king pin inclination of 8°, or is it 8 1/4°? and the Lincoln has a 4° KPI.
On the other hand, if those pins from Drake do measure .806 that sounds like they will afford a lot of clearance when reamed with the typical .814 reamer. As an aside to all of this I prefer having k/p bushings honed, just like having an engine honed with the pistons in hand to get a perfect fit.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
09-01-2017, 08:57 PM | #4 |
Try Speedway, 800 979 0122
09-01-2017, 09:38 PM | #5 |
I've used lots of kingpin kits from So-Cal with no problems I ream the bushings in the spindles to fit the kingpin and they have always fit the axle (repro or Henry) just fine.
09-01-2017, 09:44 PM | #6 |
I have after market kingpins in my truck. Tight, dennis stuff. No issues. Thinking of reworking my 36. Good info. |
09-02-2017, 12:20 AM | #7 |
I've used many kingpin sets from both Chassis Engineering and Speedway with no problems.
I've believe Drake's phone guys are trained to use this standard first response: We have never heard of that problem before! |
09-02-2017, 05:44 AM | #8 |
Zach,
All that aside........the king pin must fit at least reasonably snug in the axle. The tapered retaining pin only locates the the king pin in the axle vertically, yikes ! My only clerk/ customer experience with Drake was as you stated, it was my good fortune that Bob hisself came on the phone and could not have been more gracious. That 30 years ago. Charlie ny |
09-02-2017, 06:43 AM | #9 |
I used Pete and Jake's. They mic'd out perfect.
09-02-2017, 07:25 AM | #10 |
Thank you very much everyone! I do have 37 Ford spindles and what was to be a 37 to 41 kingpin set.
I'll look into one of the other places.... I'm sure glad not everyone is selling sets produced at the same place! Thanks everyone!
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
09-02-2017, 07:29 AM | #11 |
The Early Ford Store has NOS long right side tail light stands.They were used on the trunk back sedans.
09-02-2017, 07:48 AM | #12 | |
The long right-side would have been on right hand drive cars.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 09-02-2017 at 07:54 AM. |
09-02-2017, 09:20 AM | #13 |
I reread it and I sure wasn't clear with the statement I made in my other post. What it sounds like you did was ream with an .853 reamer, which is Lincoln size. Ford pins are only .812 and the reamer around .813/.8135. Have you tried a new pin in the axle, or mic'ed one of the old pins? Will the old pin fit the bore in the axle with just a bit of clearance? And what size is an old pin?
09-02-2017, 09:48 AM | #14 | |
09-02-2017, 10:19 AM | #15 |
I think I'm confused, but not sure?
09-02-2017, 10:49 AM | #16 |
Fordors. I used a .8135 reamer and the old pins fit it's size and the axle.... the problem is the Bob Drake pins are too small.
My mistake in mistyping the .005 as .050
-WANTED-
09-02-2017, 11:14 AM | #17 |
.005" sounds much better. Maybe the manufacturer figured the under sized king pins would fit the pressed in bushings without needing reaming ? In any case, in hind sight, one should always measure before reaming, but that's water over the dam.
I have a set of adjustable reamers which allow for any variances from stock and get a nice fit - "Loose, mit no shake", as my old German machinist used to say. |
09-02-2017, 12:15 PM | #18 |
I understand now. It's too bad that vendors never check what they are selling, and even worse that they don't care to make good on poor quality.
09-02-2017, 12:45 PM | #19 |
Tagman, I agree I should have probably measured.... but it has never been an issue as its a standardized size and the axle is always the same.
-WANTED-
09-02-2017, 01:38 PM | #20 |
I figured you missed that zero. If you want my pins you can have them for the shipping cost. I only have the pins and not any of the other parts.
(FYI: They came in a box of stuff when I purchased my truck project in 1999. They still had the receipt from Little Dearborn with them. As I remember they were purchased in the late 70's so they are probably a good quality.) |
