10-17-2019, 03:14 AM | #1 |
1936 Coupe
Hi everyone. I'm from the Model A group but need some help so I can help a widow complete her 36 coupe which is getting close.
We both live in Orange County CA if any of you are close 1. Tires.:I'm pretty sure I know this one 6.00X16. Do they use metal valve stems or rubber ? 2. Steering Wheel: I think the "banjo steering wheel is appropriate but are there other options? Rep'o's any good ? 3. Upholstery: Since LeBaron Bonney is now gone, who does she go to for material or a kit ? Thanks, I'll probably be coming back for a while on this Richard Anaheim CA [email protected] |
10-17-2019, 04:41 AM | #2 |
Re: 1936 Coupe
Hello and welcome to this corner of the Barn.
Good luck with the project. Yes, 6.00:16s all round. Not sure on stems, would suppose rubber. Not sure which steering wheels are a bolt on. What does she have? Can that be used? Someone else can chime in on the upholstery. Again. best of luck for her and you as helper. Mart. |
10-17-2019, 07:44 AM | #3 |
Re: 1936 Coupe
Welcome to the '32-'53 side.
A 1936 Ford coupe was my Dads first car when he got back from the WWII. As far as interior kits Cartouche seems to be one of the few suppliers left. https://www.macsautoparts.com/ford_m...egory_Interior Macs: I'm sure you are familiar with them coming from the model 'A' side. |
10-17-2019, 08:06 AM | #4 |
Re: 1936 Coupe
The 600- 16 should have tubes,, the inside of the rims should be blasted for any sharp edges, possibly blast the whole wheel and paint,,I like liners with tubes but thats a matter of personal preference
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
10-19-2019, 11:31 PM | #5 | |
Re: 1936 Coupe
I use tubes on my car/trucks around that yr. They share some stuff. The place I used to mount/balance my tires and tubes had rubber gaskets around the valve stems and the wheel "rim". Think it was about a 1$ each. Reasonable and reusable for tube stems. Think big trucks were metal stems. Duct tape is an "alternative" to wheel liners, not the same as the the stem gaskets I mentioned. . |
10-17-2019, 08:24 AM | #6 |
Re: 1936 Coupe
2. The banjo steering whell is also correct 3. Cartouche is the next best option since LeBarron Bonney is gone. |
10-17-2019, 10:42 AM | #7 |
Re: 1936 Coupe
You did not mention in your request for info if the car is stock or is it modified?
The banjo type of steering wheel only came on the Delux cars, to my knowledge nobody re-pops the '36 banjo. Does the car have the original wide 5 wheels, if so, you have to make sure they are 4.5" in lieu of the narrow standard type.
Bill.... 36 5 win cpe |
10-17-2019, 11:51 AM | #8 |
Re: 1936 Coupe
Classtique for upholstery, better than CarTouche others say.
Paul in CT |
10-17-2019, 12:23 PM | #9 |
Re: 1936 Coupe
didn't know there were 4.5" wide 5's.
10-17-2019, 12:36 PM | #10 |
Re: 1936 Coupe
Yes, possibly some misinformation being passed here.
All the wide 5s were 4", except the V860s which were 3.5", but the 36 didn't get the V860 so should have the 4" wheels. Mart. |
10-17-2019, 12:43 PM | #11 |
Re: 1936 Coupe
I have had wide 5's ,5.5" and 6"wide.Quite rare.They were used on Large commercial like buses etc.They only had 4 scallop openings and not all the way around.The 36 std had 3.5" wide .Deluxe were 4" wide.
10-17-2019, 02:18 PM | #12 |
Re: 1936 Coupe
Classtique may well offer very good or better upholstery, but according to their website, they offer nothing after the Model A era, which does not extend into 1936, at least in North America.
10-17-2019, 04:56 PM | #13 |
Re: 1936 Coupe
Thanks guys. That should get me started. I haven't actually seen the car in many years.I'm just acting on a phone call that asked for help.
I'm familiar with the two upholstery places recommended. Need to give them a call. Regarding tires I can unequivocally recommend Kelsey Tire, Goodyear Diamond treads for Model A's, Early V8 and the bias plys from the 60's. They are in Missouri, manufacturers and offer discounts for 50 and over quantity. You can mix sizes, black and white. Nice to deal with. It's surprising how fast you can reach that number when you put the word out. Most likely, I'll Be Baaack |
10-18-2019, 08:23 AM | #14 | |
Re: 1936 Coupe
10-20-2019, 04:49 AM | #15 | |
Re: 1936 Coupe
10-19-2019, 05:21 PM | #16 |
Re: 1936 Coupe
I have a pair of 5" wide fives for my coupe. I've been told they're off a commercial vehicle and pretty hard to find. I know guys that are building vintage race cars covet them...
Seabright Hot Rods |
10-19-2019, 05:28 PM | #17 |
Re: 1936 Coupe
my 3/4 ton 41 truck came with the wide five rims and they are 5" wide
10-19-2019, 05:40 PM | #18 | |
Re: 1936 Coupe
This is from C&G. Someone else makes it, I can't remember who right now. I'm using one and it's good enough for me.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
10-19-2019, 05:59 PM | #19 |
Re: 1936 Coupe
Richard, you know those V8,s are way better to travel in than an A
But the A is still good. Hows things, say hullo to jeanie from Carol and Me. Lawrie |
10-20-2019, 12:33 AM | #20 |
Re: 1936 Coupe
The restoration guidelines from the Early Ford V8 Club would probably be a good investment: https://shop.efv8.org/collections/fo...book-softbound
You might be able to save shipping on the tires if they could be delivered to the LA Roadster show in June. Charlie Stephens |
