Old 01-03-2020, 09:14 PM   #21
160B
160B's Avatar
Default Re: Quick question
Originally Posted by jwilliams81 View Post
You'll need to rejet your carb if you run an air filter, as they were not stock at all.
If you have your engine (splash) pans installed as factory, there isn't a need for a filter.
You will only have to resize the jets in your carburetor if the air filter you install is not adequately sized to provide the air flow for the size of your engine. See the below website.
http://www.model-a.org/filtering_air_into_carb.html
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 01-03-2020, 09:39 PM   #22
Bill G
Bill G's Avatar
I run no filter at all.
Old 01-04-2020, 06:22 AM   #23
xelhan
It's as simple as this. You spend time and effort to find the proper filter capacity, but in the end you install the worst of filters. Let alone that some prefer no filter at all
xelhan is offline   Reply With Quote
Old 01-04-2020, 04:35 PM   #24
160B
160B's Avatar
The "worst of the filters", 3.5 inch, provides 12% more filter area than required by the calculations. The 5.5 inch filter provides 194% of the required filter area and the 6.25 inch filter provides 225% of the calculated filter area.
Also keep in mind that these calculations are based on an engine running at 2800 RPM
Old 01-04-2020, 05:10 PM   #25
updraught
updraught's Avatar
K and N are a performance reusable filter. A paper filter works better in dusty conditions.
If you don't have dust and bugs you won't need to keep them out.
updraught is offline   Reply With Quote
