Old 02-19-2016, 04:57 PM   #1
josh1331
Default Replacement Switch for Heater on 1941 Ford
Anyone know of a place I could go to to buy one? John
josh1331 is offline   Reply With Quote
Old 02-20-2016, 01:55 PM   #2
TomO
Default Re: Replacement Switch for Heater on 1941 Ford
None of the switches on E-Bay are correct for a 41 Ford hot water heater. The correct switch has screw terminal, not slip on. I do have one for a hot air heater, which only has 1 speed.
TomO
TomO is offline   Reply With Quote
Old 02-20-2016, 11:55 PM   #3
josh1331
TomO thanks for reply, I assume the switch can be used if I cannot find another and was willing to be satisfied with 1speed? John
Old 02-21-2016, 08:20 PM   #4
josh1331
Can I use even though has one speed.,?
Old 02-21-2016, 10:04 PM   #5
40larry
John:
I have a used 1941 hot water heater switch here that would be correct for your heater. It has 4 screw on terminals. Call me at 818-421-0505 if you want more info.....40larry
40larry is offline   Reply With Quote
Old 02-22-2016, 09:17 AM   #6
G.M.
I recently saw some heater switches on one of the major switch manufactures
web site. I think it was one that make battery disconnect switches. I'll see if I
can find it. Google "automotive heater switch" There are lots of them on there
even auto zone has them. G.M.
www.fordcollector.com
Old 02-22-2016, 11:49 PM   #7
fordor41
fordor41's Avatar
Most "heater switches" at auto part stores are 2 speed, one direction. '41-'48 switches are 2 speed forward (heat), off and 2 speeds reverse (defrost). I tore one apart that was no good and it was like a Chinese puzzle of contacts ,etc.
fordor41 is offline   Reply With Quote
