Old 06-29-2021, 08:25 AM   #1
Standing Elk
Default Front spring perch bushings
Getting ready to replace the front spring perch bushings after having my spring re tempered and re arched. Can you usually just drive the bushings out or do you need to be split them with a hack saw blade? I will find out when I go to do it but was just curious. Thanks
Standing Elk is offline   Reply With Quote
Old 06-29-2021, 08:32 AM   #2
chrs1961815
chrs1961815's Avatar
Default Re: Front spring perch bushings
I was able to drive mine out but others may differ. If they don't come out somewhat easily don't hammer the hell out of the spring perch because you might damage it.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-29-2021, 08:53 AM   #3
Will N
Will N's Avatar
Use a nut, bolt and washers to draw the bushing into the spring eye.
Will N is offline   Reply With Quote
Old 06-29-2021, 11:37 AM   #4
nkaminar
nkaminar's Avatar
I did what Will did to install my bushings. They can be removed the same way by using a spacer like a section of pipe for the bushing to be pushed into.
Old 06-29-2021, 11:58 AM   #5
Big hammer
It depends on how worn the bushings are, if you have meat left to drive them out. I think the diameter is to small for a hack saw blade, you could roll the edges to the center and drive it out. With the spring off and a vise use a long socket the same size as the bushing and then squeeze the bushing into a long large socket, you will have to have helping hands
get a bigger hammer tap done
Old 06-29-2021, 12:16 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes, most bushings are being replaced because they are severely worn. For us, splitting them is much faster and easier.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-29-2021, 03:44 PM   #7
shew01
shew01's Avatar
I’m curious. How do you split them?
Old 06-29-2021, 03:58 PM   #8
Werner
Werner's Avatar
We call this a "fretsaw", a very small hacksaw.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 06-29-2021, 04:58 PM   #9
[email protected]
modela@aol.com's Avatar
An air hammer pointed chisel and bushing drivers. In or Out. Easy Peezee!
modela@aol.com is offline   Reply With Quote
Old 06-29-2021, 07:33 PM   #10
shew01
shew01's Avatar
Thanks. That’s the first I’ve heard of a fretsaw.
Old 06-29-2021, 07:53 PM   #11
Pete
Pete's Avatar
Use Delrin bushings for replacements as have been discussed many times here and on the early V8 forum, and you will never have to replace them again.
Old 06-30-2021, 08:02 AM   #12
BRENT in 10-uh-C
An air-powered jig saw.
https://www.harborfreight.com/high-s...saw-91753.html
BRENT in 10-uh-C
Old 06-30-2021, 09:26 AM   #13
The Master Cylinder
The Master Cylinder's Avatar
Hmmm, In the off road world, not so much.
The opinion of some reviewers:
"Delrin is the more well known-name for polyoxymethylene, and it’s used for low-budget parts. This material is a hard, stiff, and smooth plastic—which is OK, but it is prone to wear. They need replaced often and if you ride hard, you’ll find that they’re not cut out for you at all. If you’ve got Delrin, you should upgrade the first chance you get."
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 06-30-2021, 10:02 AM   #14
katy
katy's Avatar
I would try a cape chisel: https://www.protoindustrial.com/en/i...Cape-Chisels/#
Old 06-30-2021, 04:15 PM   #15
Chris Haynes
Chris Haynes's Avatar
I use the bushing driver that the same vendors that sell the bushings sell.
https://snydersantiqueauto.com/Produ...earchByKeyword
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-30-2021, 04:38 PM   #16
Vic in E-TN
Master Cylinder:
What material is the upgrade?
Where do you get it?
Vic
Vic in E-TN is offline   Reply With Quote
Old 06-30-2021, 05:38 PM   #17
Pete
Pete's Avatar
I should have said "moly filled Delrin". I assumed it was known because it has been hashed over so many times on here.
If they are kept greased as ANY bearing material should be, I haven't seen any I did wear out and some are 30 years old.
Oh, by the way, you won't think it is low budget when you find out the price of the stuff....lol
Old 06-30-2021, 08:14 PM   #18
Standing Elk
Thanks everyone, I got them out fairly easily. I had a transfer punch that was the right size to use to drive them out. I put a little heat on one side of the housing and they came out without much trouble. Thanks again.
Old 07-02-2021, 11:13 AM   #19
Flathead
Flathead's Avatar
This tool is great, takes them out and puts them in. Works on T's as well.
Flathead is offline   Reply With Quote
Old 07-02-2021, 11:33 PM   #20
redmodelt
redmodelt's Avatar
I have never had a problem using a standard hack saw blade in them or T's. T fronts are the same ID, A's are just a little longer.
